Old 01-09-2012, 04:35 PM
OHsneaky1's Avatar
Member #21954
97 sportsman 500 light problem?
Just bought a 97 sportsman 500. It sat for three years but is in great shape. However. None of the lights work. 4x4, low beam, hig, headlight. Nothing? Has new battery. Can someone give me a few ideas?? Thanks.
Old 01-09-2012, 04:48 PM
4getful2's Avatar
Member #1234
If the previous owner ran it without a battery or even a dead one,chances are it overcharged and popped all the bulbs. if not check the circuit breakers,they are in black plastic pouches
Old 01-09-2012, 04:54 PM
OHsneaky1's Avatar
Member #21954
I took the two headlights out and they are both blow? Should I go ahead ad check allthe bulbs? Even the small ones that light uptempo neutral and reverse lights?
Old 01-11-2012, 05:50 AM
OHsneaky1's Avatar
Member #21954
I removed all bulbs from their housings. And each bulb is blown. i have power there. Could it be my Regulator or could it have been something else? I will put a multimeter on it tonight and check and see. But im not sure what voltage it should be carrying? 8-10?
Old 01-11-2012, 12:34 PM
4getful2's Avatar
Member #1234
Make sure you have clean connections, at the battery first, then look at all grounds, frame and engine. If they are clean and tight and the battery is charged up. Hook up the battery and start it up, checking the charging system voltage at the battery, should be 12.5-14.5 rev it to about 3000-3500 rpm. ,if that checks out ok ,you're good to go, if the voltage starts to run away(starts climbing up to 16 volts or more) , shut it off and check the wiring connections at the regulator,which is mounted in a tight spot in front of the radiator . If after cleaning those connections and the voltage still runs away ,then you most likely have a faulty regulator.
Old 01-26-2012, 08:36 AM
ZaM's Avatar
ZaM ZaM is offline
Member #22321
totally agree on this one.
general motors headlights
polaris circuit breaker pouch
Cool LED light mod to Sportsman 300 New2quads Polaris Sportsman 2 07-31-2011 01:53 PM
2011 500 h.o. light problem?? chriswaluk ATV Repair and Maintenance 1 05-08-2011 04:55 AM
light problem CJF ATV New Members 3 10-26-2010 07:57 PM
Outlaw 50 enigine/light problem HappyTruck Polaris Outlaw 1 07-17-2010 11:41 AM
2000 scrambler light problem rodneyplaisted Polaris Scrambler 1 01-16-2010 10:13 AM
