Old 01-10-2012, 12:36 PM
OHsneaky1's Avatar
Member #21954
Dies with throttle?
I have a 97 Sportsman 500. I have changed the spark plug and cleaned all the jets in the carb and its still killing itself when you hit the throttle? I have also cleaned out fuel tank and ran it with Seafoam at idle. It starts and idles just fine. But dies once you give it gas. Any suggestions?
Old 01-10-2012, 04:09 PM
check exhaust lobe on camshaft
04 polaris sportsman 500 idles but dies when you give it gas
atv dies when give it throttle
atv dies when given gas
atv dies when i give it gas
atv dies when i give it throttle
atv idles but dies with throttle
atv stalls when i give it gas
atv stalls when i hit the throttle
atv tries to die when given gas
dump throttle atv dies
en 500 dies throttle applied
polaris 400 dies give gas
polaris idles dies when i give it gas
polaris predator idles but dies as soon as u give it throttle
polaris sportsman 500 dies when i give it gas
predator 500 idles but dies when giving throttle
predator throttle dies
sportsman 500 dies when throtteld
sportsman 500 efi will idke but dies when i give it gas
what makes a sportsman 500 die when you hit the gas
Engine dies after 2 mins, restarts after 2 mins, dies again, repeat Patriot_RAM ATV Repair and Maintenance 11 01-24-2012 09:26 AM
loss of power??? Throttle dies out?? soclean ATV General Discussion 0 01-09-2012 06:35 AM
need help, dies dudeman Polaris Predator 6 02-14-2011 04:08 PM
Twist throttle vs. thumb throttle? rsmith0801 Polaris Predator 5 03-22-2010 05:11 PM
Thumb Throttle VS Twist Grip Throttle Billster1955 Around The Garage 12 01-27-2010 07:54 PM
