01-14-2012, 12:34 PM
Member #19186
1998 sportsman rear drive shaft nightmare !!!
It all started when my right rear drive shaft broke at the main( inside not the wheel end ) the yoke ear had snapped of. I took it to a close by repair guy to see if ti was something he could handle and he thought he could.He replaced the broken part not the entire shaft replaced all joints on both sides and when I took it home rode for approx. half hour the joints popped on the left side. took the machine back he was somewhat puzzled but was going to replace joints because he thought they may have been bad.Replaced and took for test ride before calling me blew them out again this time damaging the yoke on this shaft (inside same as other side).Ordered new part replaced just part and new joints because everytime they just blow apart needless to say.I picked it up today rode for another half hour and shaft broke again this time the outer yoke (the wheel side). Was hoping to get some educated thoughts on this delema.Thank for any input in advance.
01-14-2012, 01:55 PM
Member #19186
Iwas wondering if I should post on different thread with this ?
01-14-2012, 06:06 PM
so yhe u-joints are breaking? see if you can get complete axle from the cv-man on ebay, probably cheaper than parts from polaris
01-14-2012, 06:25 PM
Member #19186
I looked up cv-man didnt find anythjng . Iwas wondering if there is a certain way to set the two shafts for balance and if that is what could be making the joint pop and break the yoke or if the steel on the old parts are just fatigued. Iwill be replacing the entire shaft with new but this has been an expensive lesson for the repair man on my dime.
01-15-2012, 04:38 AM
Call the cv man, 1-800-338-2326 Ill bet they just dont list the older style , but I think they make them
01-15-2012, 05:02 AM
Member #19186
I will give them a call thanks.
01-15-2012, 11:40 AM
Member #3687
I think the u-joint you are putting in it is the wrong size. If they are correct make sure the wheel bearing is not locking up and causing the u-joint to come apart.
01-15-2012, 01:09 PM
Member #19186
I hope that the repair guy is  not making this mistake or some other stupid stuff and not realizing it,but I am starting to wonder.I have had the bike back to him for three times know going on four.I am going to get complete shafts with the joints already installed and let him install and hope to be done ,this is costing more than the bike is worth.Your probably thinking why take it back to this repair guy but I have paid him to fix the bike and its not.
1997 polaris sportsman u joint axel removal, 1997 sportsman 500, 1998 335 polaris sportsman shaft drive, 1998 polaris sportsman drive shaft 1380110, 98 polaris rear half shaft, 98 sportsman rear prop shaft, do atv drive shafts have to be in time, ho remove a drive shaft from trannsmision 1997 polaris sportsman, how to install a rear drive shaft on a 98 sportsman 500, how to remove drive shaft sportsman, inside of polaris sportsman 500 shaft drive transmission, polaris 98 sportsman rear u joint replacement, polaris atp driveshaft, polaris broken drive shaft, polaris rear half shaft removal, polaris sportsman 500 broke half shaft, polaris sportsman 700 propshaft, what causes the rear drive shaft to break on polaris sportsman, what is a prop shft on a 1997 polaris atv, what size or measurment is on the outer yoke on 1997 polaris sportsman
