01-14-2012, 09:02 PM
Member #22269
what exactly do fans on atvs do?
are they really that important? what do they do??
01-14-2012, 09:11 PM
Member #10066
Very important. Same thing they do in vehicles, they prevent your engine from overheating.
01-14-2012, 09:21 PM
Member #22269
how do they prevent that? i thought the radiator would do that job
01-14-2012, 09:48 PM
Member #10066
The radiator alone can't do it. That is where the fan comes into play. The fan pulls the heat from the radiator fins to cool down the coolant before it goes back through the engine.
01-14-2012, 10:17 PM
Member #22269
oh okay i gotcha. thanks alot
01-15-2012, 07:55 AM
Exactly!
If you are constantly moving fast enough and never stop, the fan isn't needed.(unrealistic though) But for slow stuff and stopping, the fan pulls air through the radiator.
This keeps your machine from over heating at idle or slow speeds. A machine would likely overheat while snow plowing with a fan.
01-15-2012, 02:35 PM
Member #20739
Exactly!
it was 5* the other night while i was plowing and my fan kicked in twice.
2011 sportsman 550 EFI
-heated grips
-polaris 2500# winch
-AcerBis uniko atv handguards
-moose 48" plow
01-15-2012, 02:40 PM
Exactly!
Crazy huh? Little bugger makes a lot of heat.
01-15-2012, 02:59 PM
Member #22269
well mine doesnt kick in at all is why i ask lol. it runs hot. antifreeze runs into the reservoir boiling. i cant ride it like this. ordering a new fan that i hope will fix the problem...
01-15-2012, 03:27 PM
Member #19003
well, test the fan.
It's the fan or the fan temp switch.
1..unplug the fan and put 12v to it and see if it runs.
if it does..
2. plug the fan back in. Look on your radiator for a plug with a couple wires going into it. Unplug it. Jumper the 2 wires and turn the key on and see if the fan comes on. Also, not sure, some fan switches are closed to run and closed to stop. That means that 1 way or the other, you can test the switch.
I'd bet your fan quit or has something in it.
You could also spin it around with the key OFF and see if it spins freely.
09 850xp
30" Zillas Blk 212's
atv should light come on when fan does?, do atv fan pull air?, is polaris magnum 325 6 or 12 volts, what do temp switches do on atvs, whot does the fan do in atv
