Old 01-16-2012, 07:03 AM
gazgaz's Avatar
Member #22353
455 Diesel smokey help
hello
wounder if you can help i have a polaris 455 diesel
the bike starts fine but is kicking out blue smoke . there seams to be an oil leak wile running not found were from . and sounds like tapping / knocking
any help on what i need to do to correct this
thanks gaz
Old 01-16-2012, 04:47 PM
Old 01-17-2012, 07:54 AM
shore's Avatar
Member #19003
blue/white smoke from a diesel is usually valves or rings worn.
find the figure and run a compression test on it. Remember, diesel are much higher compression than spark engines.
09 850xp
30" Zillas Blk 212's
Old 01-21-2012, 07:31 AM
gazgaz's Avatar
Member #22353
service manual
hello
i wounder if anyone has or knows were i can get service manual for my polaris 455 diesel so a down load would be best
thanks gaz
Old 02-05-2012, 10:17 AM
B-Ray's Avatar
Member #6870
The blue smoke could be oil but I would suspect its fuel smoke related to an injector problem or a timing problem. Bad fuel, or weak or faulty injectors can change timing and cuase fuel smoke.
The tapping / knocking could be a "fuel knock" which is caused by incorrect timing. The condition of the fuel injectors can change the timing meaning fuel is injected at the wrong time. Diesel engine have high compression / cylinder pressures combine that with the injection of fuel at the wrong time and you get a fuel knock.
change the fuel filter and try running the engine on a fresh source of fuel from a fuel can see and see if it changes. If it does then the fuel quality was the issue. If no change then remove the fuel injectors and have them tested a local fuel injection shop. It should cost less than $25 for testing if they can adapt to them.
how long have you had this machine and any history with bad fuel or water?
2011 Sportsman XP EPS 550 Browning Edition
2010 Sportsman XP EPS 850
2000 Sportsman 500
Old 02-05-2012, 04:23 PM
goombadi99's Avatar
Member #2057
I doubt its oil. If the diesel is anything like a truck diesel than the engine would rev out of control. Look up you tube videos its called a run away diesel when oil enters the combustion chamber on a diesel. Ive seen them run 10000 rpms when thisbhappens.
2011 850 xp
3000 winch
polaris hand gaurds
front lock n ride box
rear lock n ride backrest,box
Big Gun eco slip on.
27in ITP XTR Tires
99 polaris 455 diesel owners manual
99 polaris diesel who built the motor
diesel polaris atv
histori polaris 455 diesel
oil atv diesel polaris
polaris 455
polaris 455 diesel
polaris 455 diesel atv
polaris 455 diesel engine
polaris 455 diesel engines
polaris 455 diesel manual
polaris 455 diesel repair manual
polaris 455 diesel service manual
polaris diesel forum
polaris diesel sportsman 455
turn up fuel polaris 455
who made polaris 455 diesel engine
wrecked atv for sale
Almost a 'diesel' knock 30calpal ATV Repair and Maintenance 0 02-15-2011 02:12 PM
polaris diesel D BAT 400 HG jim fraser ATV Brakes & Suspension 0 11-25-2010 09:06 AM
polaris diesel D BAT 400 HG jim fraser ATV Brakes & Suspension 2 11-25-2010 09:01 AM
2011 Polaris Defense new diesel ranger xp shank0668 ATV General Discussion 0 07-06-2010 07:48 PM
'99 Diesel Conversion rjrkihap ATV Repair and Maintenance 2 11-02-2009 11:31 AM
