Old 01-16-2012, 06:54 PM
shui5612's Avatar
Member #19703
850XP start...
well i trailered my atv in to take a course, starts fine on the trailer, i let it run for 7 minutes while i back up and take it off the ramp...
i go into the lobby to fill in some papers, come back BAM it wont start, it cranks and such but doesnt run...
im getting worried here and there now...
what i do... disconnect the battery from a terminal, and reconnect it, it starts fine... did have to do the same after i shut if off (idled for 10 minutes and 3 minutes or so of riding here and there)
and had to re-do the same procedure to get it started...
just wondering what might have caused it besides the cold (-20C)
and how did the removing battery fix this.. i cant really explain ..
oh and getting the front hood off was also some trouble... the lock and rides FROZE... had to remove the top lever and pin to remove the hood...
so any ideas what caused this? and no, my 850did not have the first maint...
2007 800EFI X2 Deluxe
-polaris 2500# winch
-tool grips
-VIP air windshield
-safety flag (polaris)
-Glacier II plow system
-front hitch
-1700KM
2010 850 XP EPS
- 2500# polaris winch
- VIP air windshield
-498KM
Old 01-17-2012, 07:52 AM
shore's Avatar
Member #19003
1st off they don't like to idle when started cold...and by that I mean they foul plugs. Crank it up, let it warm up for a minute and then ride it. Don't just let it idle for 10 minutes.
This doesn't seem to be an issue when they are warm.
09 850xp
30" Zillas Blk 212's
Old 01-17-2012, 12:57 PM
shui5612's Avatar
Member #19703
well... the atv idled for 10 mins (did some throttle changes here and there for 3 minutes)
then i rode it off the trailer, up a small hill, then forward, then back ward.... so id say 3 minutes of 'driving" it...
i mean i didnt go 5000 rpm for 50 miles... but maybe did a solid 2 minutes of above 3500rpm...
the plug didnt foul as it ran GREAT afterwards....
-tool grips
-VIP air windshield
-front hitch
-1700KM
2010 850 XP EPS
-498KM
Old 01-17-2012, 01:03 PM
shore's Avatar
Member #19003
What it does is over fuel when cold so the plugs are getting wet. You turn it off and all that fuel is in there. It never gets a chance to get off the enrichment cycle. It'll run on it but it won't restart easily. Crank it up let it warm a minute, ride it until it's warm.
This is pretty common actually. The dealer can reflash or you can switch plugs to the iridium ones. The dealer won't know squat about the iridium plugs. You have to find them online or a german auto parts supplier.
09 850xp
Old 01-17-2012, 04:11 PM
shui5612's Avatar
Member #19703
thanks... might be switching the plugs soon... and when i do ill get those iridium...
im overall satisfied with the machine... just that it was a "shock" to me for it not to start...
the only problem with your theory, is that even my dealer was stumbled,
IF I DISCONNECT the battery... it STARTS RIGHT UP... like it usually does....
i dont see this happening with a fuel flooded engine,
nor with a "dead" battery... nor fouled plug...
care to explain why this is happening and how it is fixing it?
-tool grips
-VIP air windshield
-front hitch
-1700KM
2010 850 XP EPS
-498KM
Old 01-17-2012, 04:52 PM
shore's Avatar
Member #19003
I don't know if this is your particular issue but they are known to foul plugs from quick starts and then turning them off.
09 850xp
Old 01-17-2012, 05:45 PM
shui5612's Avatar
Member #19703
thats what im saying... im 100% sure its not the fouled plug... as it worked FINE for hours after that......
and my 800 never had such problems... even if its 850 specific... it was no where near a quick start and shut down....
anyone other have some input?
and thanks you for your help and time, shore!
-tool grips
-VIP air windshield
-front hitch
-1700KM
2010 850 XP EPS
-498KM
Old 01-18-2012, 04:26 AM
loose connections at battery or selenoid?
Old 01-18-2012, 09:30 AM
shui5612's Avatar
Member #19703
thats improbable... the engine cranked... really well even... all electricals worked...
so..... this `problem` is puzzling me.. also puzzled my dealer...
-tool grips
-VIP air windshield
-front hitch
-1700KM
2010 850 XP EPS
-498KM
Old 01-18-2012, 09:47 AM
shore's Avatar
Member #19003
Have you tried adjusting the throttle slack in the bar housing?
They are real touchy about that being correct.
Also, some people reported a stocky throttle position sensor. They simply thumbed the throttle a few times and it came back inline.
09 850xp
2012 850xp wont start
2012 polaris 850 xp starting problems
2012 polaris 850 xp wont start
2012 polaris 850xp starting problems
850 xp cranks but will not start
850xp stumbles
850xp wont start
can you crank 2012 polaris 850 xp underwater
do you need to let idle for 2012 850 xp
polaris 850 atv won't start when cold
polaris 850 crank positioning sensor
polaris 850 no start after trailering
polaris 850xp backup starter
polaris touring atv wont start
2009 850XP Jerky Start jdb8025 Polaris XP 24 10-08-2011 01:55 PM
2006 outlaw wont start when cold but will start when warm. heavyritefoot Polaris Outlaw 6 05-09-2011 01:42 PM
Wont start from a cold start. gramslam05 ATV Repair and Maintenance 5 11-28-2010 05:57 PM
new 850xp ohchevy ATV New Members 10 05-17-2010 04:59 AM
Phoenix won't start with start button Dodgeboy Polaris Phoenix 1 10-19-2009 07:17 PM
