01-17-2012, 04:33 PM
Member #20739
Anyone run a "chafe" gaurd on there winch??
As the title says?
When I got my synthetic rope for my winch it came with a nylon sleeve aka chafe gaurd, I was wondering if anyone else was useing one? mine got bunched up in my winch and caused me some issues. Anyone else had this problem? If so how did u fix it, besides removing it.
2011 sportsman 550 EFI
-heated grips
-polaris 2500# winch
-AcerBis uniko atv handguards
-moose 48" plow
01-17-2012, 05:57 PM
Member #22242
Originally Posted by shep
As the title says?
I have been using the synthetic rope for 2+ years now & never used a chafe guard, with no issues at all.
I plow snow & have pulled myself out of some pretty deep mud holes with the synthetic & have had no probs.
I would say if its causing you issues remove it. JMO
 2012 Polaris Sportsman 550 touring
2001, Polaris 550 Indy Sport Touring
01-17-2012, 07:13 PM
Member #20739
As the title says?
Probably what I'll end up doing, just thought maybe someone had the same issue
-heated grips
-moose 48" plow
01-17-2012, 07:25 PM
Member #11247
I did, and cut the stupid thing off. You could slide it down the line and wrap it up in the drum if you wanted to keep it.
2011 Trail Boss - HIDs SOLD
01-17-2012, 07:44 PM
Member #15647
I had the same problem as you, so what I did was I pulled the rope and the chafe and duct taped it on both ends and solved the problem.
01-17-2012, 08:41 PM
Member #10066
I agree it is a pain when spooling in or out, but I just deal with it. Because I know the second I cut it off the rope will get chafed on a rock or tree the next time I use it. When unspooling I grab the end of the chafe guard and the hook with one hand and pull it out. When spooling in I help the chafe guard in 6" to 12" and then it feeds itself in the rest of the way.
01-18-2012, 02:25 PM
Member #21250
2011 500 H.O.
01-18-2012, 02:28 PM
Member #20739
Originally Posted by JimT
Mine looked the exact same way, until I plowed my drive way twice?!?
-heated grips
-moose 48" plow
01-18-2012, 02:47 PM
I keep mine further inside the spool. This way if I need it I can pull it down to protect the rope if needed. For plowing it causes issues & only gets in the way.
01-18-2012, 04:37 PM
Member #20739
And it doesn't get all scrunched up then? I'll give that a try talking another 4-8 onfriday
-heated grips
-moose 48" plow
atv dealers in chafe ny, chafe guard warn winch atv, how do i fix my synthetic rope for winches, synthetic chafe guard, winch rope chafe guard
