Old 01-18-2012, 09:14 PM
medic2491's Avatar
Member #19682
Symtec heated grips install
Just installed the Symtec heated grips/thumb warmer on our 2008 500 HO. I'm not wicked handy so if I can do it, you probably can too! Very straight forward. As for wiring, I put the positive and negative wires on larger spade connectors with the wires going into the accessary plug. When people say these grips get hot they are not kidding! On full power, I couldn't keep my hands on for more than 5 seconds.
This is my plowing ATV, so as you can see, I also installed an adult beverage holder from RAM. Works great. It has a self correcting yoke, so no matter what angle you're at, your libation stays level. Also just installed another RAM mount on our other ATV. This one is for my GPS.
Old 01-19-2012, 12:14 AM
crazyjoe's Avatar
Member #20921
Nice work! I love the self leveling beverage holder, too cool!
2011 Sportsman 800 EFI, bone stock
Old 01-19-2012, 03:46 AM
KICKER431's Avatar
Member #18006
my very favorite accessory; my symtec grips. The beverage holder may be #2
2004.5 Sportsman 700 EFI
2007 Sportsman 700 EFI
Old 02-12-2012, 09:33 AM
CapAmerica's Avatar
Member #16284
Hi there,
It only takes 1 ride in the cold know I'm gonna need heated grips too. How difficult was it removing the factory grips? Any tool / process suggested to remove them?
Old 02-12-2012, 09:38 AM
medic2491's Avatar
Member #19682
I got the tip from here. To remove the factory grips, just take a compressor with a "spray" nozzle on it and put it in the hole on the end of the grip. Block the hole in the other grip with your finger or tape. Then just spray and pull. Very easy.
Old 02-12-2012, 09:54 AM
KICKER431's Avatar
Member #18006
The Symtec grips come with the heating elements built into new grips, the tool I used to remove my factory grips was an exacto knife. Split 'em right down the middle.
Old 02-12-2012, 09:57 AM
CapAmerica's Avatar
Member #16284
Cool, thanks guys. I guess I can try Medics way first then if that fails use Kickers. I'll probably go with the Symtec's.
2010 Sportsman 500 HO.
ProMark 2500 Winch
Warn Front Mount SnowPlow
3way High Beam
Symtec Heated grips
Quadovator reverse Override
Old 03-18-2012, 03:19 PM
CapAmerica's Avatar
Member #16284
UPDATE: Got the Symtec grips installed and tested successfully!! The existing grips came off easily with a single slice of my utility knife. followed the instructions for using WD40 and hit it with a hair dryer for the last two minutes as an extra kick and the new grips slid on 1 shot. I cut some of the slack out of the wires, connected it to the accessories ports power and ground and mounted it on the pod face. I'm ready for next winter now!!!
Thanks for the info guys, appreciate it.
ProMark 2500 Winch
3way High Beam
Symtec Heated grips
Old 03-18-2012, 03:48 PM
KICKER431's Avatar
Member #18006
Nice job Cap. Sounds like just the way I did it. I mounte dmy control below the speedo rather than to the side. But otherwise the same. You will not regret these next winter.
Old 03-18-2012, 03:55 PM
PolarisRich's Avatar
Member #7183
When I bought my bike the Symtec grips was the first mod I purchased and let me tell ya it was every penny! Like you said, when you set them to full power they get DAMN HOT!!!
2005 Polaris Sportsman 500 HO
26" Mudlite XL's, Clutch Kit, 3 Headlight Mod, 1/4" Front Wheel Spacers, 1" Front Spring Spacers, Uni Filter, Heated Grips, 12V Electrical Accessory Panel, Etrex GPS Handlebar Mount and hardwire, Passenger Seat with Cargo, Horn, Snorkeled Vent Tubes, Mossy Oak Graphic Vinyl Wrap, 2500 Runva Winch.
3 way heated atv grips
atv heated grips installation
atv heated grips symtec
best atv heated grip
heated grip symtec installation
help putting heated grips on atv
how to install polaris heated grips
how to install symtec heated grips on atv
installing heated gips on a sportsman 700
installing symtec heat grips
polaris sportsman atv heated grips
polaris sportsman heated grips
symtec 4 zone heated grips
symtec heated grip install
symtec heated grips
symtec heated grips how to install
symtec heated grips install
symtec heated grips installation on polaris
symtec heated grips instructions
help with wiring symtec heated grips Tikka338 ATV Repair and Maintenance 8 12-24-2011 01:42 PM
Heated Grips on 2011 850 TNWB ATV General Discussion 2 12-24-2011 08:24 AM
Best Heated Grips? RubiconChris Polaris Sportsman 28 11-13-2011 03:46 PM
Heated grips MARVINFISHER ATV General Discussion 11 10-26-2011 03:09 AM
Symtec 4 Zone Heated grips Avatar Grove ATV New Members 3 06-04-2011 02:55 PM
