Old 01-18-2012, 10:04 PM
maddogg's Avatar
Member #17715
belt, clutch or motor mounts
i have a 1997 explorer 500 that i just put new motor mounts in. i put new ones in because the motor was twisting when you rev it up causing the belt to wear fast and not shift right. well it still doing it. any ideas why? it still twisting after new belt new motor mount. take the clutch off the motor and it does not twist when reving up but with it on it does. any ideas
Old 01-19-2012, 05:12 AM
Old 01-19-2012, 12:50 PM
4getful2's Avatar
Member #1234
check the rear clutch buttons,and spring
Old 01-20-2012, 10:25 AM
maddogg's Avatar
Member #17715
well after replacing all motor mounts the driven clutch seems to be the problem i hope this is the problem
motor mounts tatcat ATV New Members 2 03-15-2011 06:05 PM
400 scrambler complete motor carb clutch for sale lbmfpeterson Polaris Scrambler 0 01-15-2011 05:55 AM
Clutch or Belt ???? Any Help Rip it up ATV Repair and Maintenance 1 05-21-2010 03:51 AM
clutch belt bomberboat ATV Repair and Maintenance 1 01-17-2010 12:42 PM
Belt housing gasket ? and water splashing on the motor causing it to cut out lifted89xj Polaris Sportsman 6 08-16-2009 08:13 PM
