Old 01-22-2012, 06:33 PM
Downey's Avatar
Member #22572
Need some help quick please!
Looking at buying a 99 xplorer. But it needs a motor or at least a crank. How much should it cost for the motor? Or the parts to get it. I need something to plow snow with.
Old 01-22-2012, 06:42 PM
A crankshaft alone is probably going to be in the $500 range. Plus seals, gaskets, bearings, labor, etc etc etc.
With its age, you probably are not going to be able to find a complete running motor, and this one is going to cost some $$$. If you can do it yourself, then that helps, but if your not comfortable building an engine from the ground up (I'm not, I wouldn't build my own motor) then its going to be expensive to fix.
This thing has almost no value as is. I wouldnt pay more then $50 or $100 for it. At least if you pay $100 for it, and it turns out it is going to cost $1500 to fix the motor, you can part the rest out and get your $100 back.
Old 01-22-2012, 08:13 PM
need help quick 335polaris ATV Repair and Maintenance 2 08-01-2011 05:42 PM
need help quick 335polaris ATV General Discussion 4 07-06-2011 09:33 AM
Need HELP Quick mngatorhunt Polaris XP 13 03-25-2011 05:15 AM
Quick Q? MNPolaris850XPeps ATV Wheels & Tires 2 02-01-2011 06:31 PM
Need a quick fix 4chevys4me ATV Repair and Maintenance 4 05-29-2010 07:49 AM
