Old 01-25-2012, 11:21 AM
DTH357's Avatar
Member #19232
Angry 850 Touring Lift Kit
Has anybody put one on before,and does it help that much.When me and the wife ride this thing sinks to the frame in any deep mud.I have 27" ITP m/s 589 tires on it.It is a 2012,so nobody has a lift for it.Any help would be greatly appreciated.
Old 01-25-2012, 11:32 AM
bobx2's Avatar
Member #14376
I don't really think a lift will keep it from sinking.
Old 01-25-2012, 11:48 AM
Fishy's Avatar
Member #10336
Catvos can build you a lift kit but you will also need to replace the stock axles or they will bind and break.
A four-wheeled adventure will soon bring you happiness.
2011 Sportsman 850 Touring Super Graphite L.E. (Mine)
25.5" Pitbull Rockers on 14" Polaris L.E. Wheels (Mine)
2009 Sportsman XP 850 EPS Sunset Red (Hers)
26.5" Pitbull Rockers on 14" Polaris L.E. Wheels (Hers)
26" Maxxis Bighorns on 14" Black Polaris Wheels (Spares)
Old 01-25-2012, 12:37 PM
lost cause's Avatar
Member #9763
There is currently no bolt on lift for that machine yet. Only options right now are HD springs and/or larger tires. Or like stated above, call CATVOS and they can build you a custom lift.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 01-25-2012, 01:32 PM
shui5612's Avatar
Member #19703
the ONLY options to stop it from sinking are:
loose weight... haha just kidding.
larger tires... maybe spacers and larger tires...
the question is, Do you KNOW whats under the mud?
if i KNEW that under 14" of mud there was an asphalt road then a lift WOULD help as the tires could reach the bottom and the underside of the machine wont touch the ground (saying you have 12" of clearance) .
you get stuck because you loose momentum, mostly because of increased friction and loss of traction...
a lift would help you loose some friction as the underside WONT touch but this will only result in you going abit further...
however, you still wont have any traction, the only options are either digging deeper (lift and skinny tires) IF the bottom provides more traction (harder mud for example)
if the bottom DOESNT help, the other option is to try and float ontop of the mud, yet again the traction will be limited but might aswell get you OVER the mudhole.
the only way to do this is to get larger tires or tracks....
hope i helped.
2007 800EFI X2 Deluxe
-polaris 2500# winch
-tool grips
-VIP air windshield
-safety flag (polaris)
-Glacier II plow system
-front hitch
-1700KM
2010 850 XP EPS
- 2500# polaris winch
- VIP air windshield
-498KM
Old 01-31-2012, 09:37 AM
lost cause's Avatar
Member #9763
Highlifter has confirmed that their lift for the touring will work on the 2010-2012. You will need different front axles or their axle bar kit though.
EPI HD SPRINGS
1.5" SPACERS
GORILLA AXLES
SUPER ATV ARMATURE
K&N FILTER
POLARIS 3500 WINCH
Old 01-31-2012, 02:30 PM
DTH357's Avatar
Member #19232
Thanks,I ordered it today.
2010 polaris sportsman 850 touring lift kits
2011 touring 850 with lift
2012 polaris sportsman touring lift kits
850 polaris touring lift kit
lift kit for polaris 850 touring
lift kit polaris sportsman touring
pitbull atv tires on polaris 850 touring 2012
pitbull rockers polaris touring
polaris 850 xp touring catvos lift kit
polaris atv 850 lift kit
polaris atv forum
polaris sportsman xp touring lift
sportsman 850 eps lift
2008 Touring 800 vs 2011 Touring 500 krzgoat ATV Purchasing and Price 9 11-05-2011 08:25 PM
Best lift for xp 850?? MN POPO ATV General Discussion 3 02-14-2011 03:18 PM
touring 6" lift kit bluedog ATV Brakes & Suspension 1 01-21-2011 12:43 PM
Sportsman touring 850 lift kit RXevol ATV Brakes & Suspension 3 10-28-2010 01:24 PM
2010 touring seat fit an 09 touring? HONDARACER Polaris Sportsman 3 03-29-2010 10:49 PM
