01-26-2012, 06:14 PM
Member #22687
wiring to the ignition switch
I am installing a winch on my 2003 polaris 4x4. I am trying to figure out what colored wire is the hot one coming from the ignition switch, that way the winch will on be turn on when the ignition is.. can anybody help.
01-26-2012, 07:01 PM
01-26-2012, 08:15 PM
Member #10066
If Polaris used the same wiring colors on the on older models then it will be the orange with white tracer on it. Mine is a 2010 though. If you find that color wire, check it with a multimeter.
01-26-2012, 09:27 PM
Member #22687
01-26-2012, 09:31 PM
Member #22687
thanks,, I have never been on this site before and that was a quick answer,,
01-26-2012, 10:29 PM
Member #22698
Polaris keyed-power circuits are: red with a white tracer prior to appr. 2008, orange with a white tracer thru the current models. Hope this helps. Chuck
03 polaris atv wirering, 08 polaris ignition key and wires, 2000 polaris scrambler 500 ignition fuse, 2008 polaris sportsman 500 winch installation, orange-white wire, 2010 polaris scrambler ignition fuse location, 2012 polaris sportsman ignition wire, atv ignition switch colors, how to jumper key switch wires on 01 polaris scrambler, how to test ignition switch 2003 sportsman, how to wire a general ignition switch, ignition key wire on polaris xp, ignition switch wiring for a polaris scrambler 500, polaris atv how to test ignition key, polaris atv ignition switch, polaris ignition switch wiring, polaris scrambler ignition wire diagram, polaris scrambler key switch wiring, power wire for winch polaris scrambler, wire color for ignition on 2008 sportsman, wiring keyswitch polaris sportsman
