Old 01-28-2012, 08:27 AM
brutus323's Avatar
Member #22618
fuel gauge flashing
i have a 2012 Polaris Sportsman 500 H.O. - Polaris Pursuit Camo LE and picked it up monay--just filled it up and the gauge is flashing "fuel" like it is low. i checked the shut off and it is on....any ideas or suggestions? thanks
Old 01-28-2012, 11:53 AM
4getful2's Avatar
Member #1234
call the dealer and take it back
Old 04-01-2012, 11:55 AM
ssnowden's Avatar
Member #24767
I had the same problem with my 800 EFI. i took the fuel pump out of the tank and removed the arm that holds the float. My float would sink to the bottom of my tank. I took a wine cork and installed it were my float was. I then coated the cork with fiberglass resin. I then reinstalled the fuel pump and my gauge works perfectly now. I hope this will help you and any others that might be having this problem.
Old 04-01-2012, 12:02 PM
KICKER431's Avatar
Member #18006
I am with 4getful2. If you just picked it up Monay, let the dealer fix the float. You shouldn't have to already. If it happens out of warranty, then follow ssnowden's advice or buy a new float.
2004.5 Sportsman 700 EFI
2007 Sportsman 700 EFI
07 polars fuel gauge
2009 polaris atv 500 gass gauge blinks
2012 polairs fuel gauge blinks
atv gas gaude flashing
fix for flashing fuel guage polaris 500 ho
fix fuel gauge flashing polaris
fuel gauge flashes polaris atv
gas gauge for polaris atv
gas hand blicking on atvs
need fix for polaris flashing fuel guage
polaris 500 sportsman fuel flashes
polaris 700 fuel gauge flashing
polaris atv flashing gas gage
polaris flashing fuel gauge
polaris fuel gauge blinking
polaris fuel gauge flashing
polaris gas gauge flashing on/off atv
polaris sportsman fuel gage flashes
sportsman fuel guage blinking
Fuel gauge flashing lildsel ATV New Members 4 12-10-2011 09:13 PM
Fuel gauge tricky27x ATV General Discussion 6 07-06-2011 06:46 AM
Help! '07 Sportsman 500 Flashing Speedometer Needle & Fuel bars ruffster ATV Repair and Maintenance 2 01-20-2010 07:39 PM
fuel gauge pal95mon ATV General Discussion 2 12-27-2009 07:15 AM
Fuel gauge sjcarp ATV General Discussion 0 09-03-2009 03:03 PM
