Old 01-29-2012, 01:55 PM
ronster's Avatar
Member #3156
07 sportsman running bad
my 07 sportsman 800 is running bad, it will run good for a while then it will cut out and act like its running on 1 cylinder. dies if i let off the gas, then all of a sudden it will start running good again. anybody tell me if they have had this problem?
Old 01-29-2012, 04:10 PM
is it ticking like a stuck lifter?, if so add 2 oz of seafoam to your oil, ride it for 30 minutes and see if tickin goes away, then change your oil and filter, the oil that comes out will be black cause of the cleaning the seafoam did, Ive done this to a 6 and 700 , freed the sticky lifter and all was well
700 sportsman running bad?
polaris sportsman running rough
2004 sportsman 400 running hot ridgerunner63 Polaris Sportsman 3 05-12-2011 01:28 PM
2004 Sportsman 700 running bad rifleman24 ATV Repair and Maintenance 3 03-13-2011 05:23 PM
94 sportsman running rough Andrew85 Polaris Sportsman 5 12-28-2010 07:05 AM
98 sportsman 500 running hot greenvilleman ATV Repair and Maintenance 3 04-18-2010 09:29 AM
06 Polaris Sportsman 800 EFI quits running after an hour of running perfectly buckshotmudder ATV Repair and Maintenance 1 03-29-2010 07:23 PM
