Old 01-30-2012, 05:47 AM
ghodge's Avatar
Member #20378
RotoPax on 850 Touring
Has anyone bought the 4 gallon rotopax with the 850 touring? I would like to store it on top of the front cargo bin. Has anyone tried to just strap in down without mounting the hard brackets. It looks like you could attach it at the side with some small straps to the small plastic slots of the cargo box.
2011 850 Touring Graphite LE
Maxxis Bighorns, 1.5 " spacers
TCP Boot Guards
Polaris front & rear bumpers
Rotopax 4 Gallon & Mounting plate
Garmin eTrex and RAM Handlebar Mount
Direction2 Fender Flares
Old 01-30-2012, 06:09 AM
Fishy's Avatar
Member #10336
You would definitely want to mount it for security, a 4 gallon fuel pack will move rapidly if not properly secured and may prevent you from being able to steer. I have mine securely mounted and have full steering ability.
A four-wheeled adventure will soon bring you happiness.
2011 Sportsman 850 Touring Super Graphite L.E. (Mine)
25.5" Pitbull Rockers on 14" Polaris L.E. Wheels (Mine)
2009 Sportsman XP 850 EPS Sunset Red (Hers)
26.5" Pitbull Rockers on 14" Polaris L.E. Wheels (Hers)
26" Maxxis Bighorns on 14" Black Polaris Wheels (Spares)
Old 01-30-2012, 06:22 AM
ghodge's Avatar
Member #20378
Thanks. I kind of figured that (looking for cheap). Did you fabricate a metal plate for underneath the lid to secure the mounts or just drill through the plastic and bolt directly to the lid (in between the checkerboard slats)? Does the lid open and close easy enough with the rotopax mounted?
TCP Boot Guards
Old 01-30-2012, 08:48 AM
Fishy's Avatar
Member #10336
I attached the brackets to the top of the box temporarily with 2 way tape to make sure I could fully turn the handlebars and open the box. I then proceeded to drill thru the mounting holes, I trimmed the checkerboard slats where needed and attached the bolts with washers for added security. I then used a window sealant on the inside over the bolts/washers to prevent any water penetration. For added security I added a 2nd cable inside the box to account for the extra weight of a full fuel pack.
Old 01-30-2012, 09:42 AM
bobx2's Avatar
Member #14376
I agree with Fishy. You want it secured so there’s no way it can move. I also drilled through the box lid. I used the mounting plates from Rotopax on the inside of the lid for a good solid mount. I siliconed the holes through the lid just before installing the bolts for a water tight seal. Haven’t had any water get in the box at all.
Old 01-30-2012, 10:03 AM
Canonball's Avatar
Member #10473
I put it on the front box - mounted with metal bracket:
Ingo
Old 01-30-2012, 10:21 AM
ghodge's Avatar
Member #20378
Thanks to all. Great ideas. I specially like reinforcing the cables on the lid and using sealant to insure it's watertight. I might actually even get the universal mount, it comes with 2 of the mounting brackets and is flexible as to how you mount it and you can spread the load over more of the lid. It's only $15 more than just buying 2 of the mounting brackets. Thanks again.
TCP Boot Guards
Old 03-05-2012, 07:58 AM
Mastroz's Avatar
Member #19400
how was the packs mounts on the back of the quad? I wanted to get it mounted somehow on the back, but its hard to tell from some of the pictures. What about water leaking in the front?
Old 03-05-2012, 10:22 AM
ghodge's Avatar
Member #20378
I mounted mine like Canonball. I used a lot of silicone sealant. I bought the mounting plate for extra stability. I used sealant all around the holes underneath the plate on the topside and all around the bracket on the underneath. I also used sealant on the screws. I'm thinking it will be dry.
TCP Boot Guards
Old 03-05-2012, 10:38 AM
Canonball's Avatar
Member #10473
I used washers out of gum.
Great. No water in the box.
Ingo
1 gallon set rotopax for polaris 850 front box
850 xp rotopax forums
atv guru rotopax
atv guru rotopax rear bumper
cheap rotopax
installing rotopax for polaris 850 front box
polaris rotopax mount
rear bumper and rotopax mount for polaris
ropopax on polaris 850
roto pax for polaris850 tourn
rotopax clamp mount atv guru bumper
rotopax for 2012 sportsman
rotopax for polaris touring
rotopax forums
rotopax inside mount
rotopax mounting on polaris 850
rotopax on polaris 850
rotopax polaris 850
sportsman 850 skid red
Rotopax's kujones79 Polaris Sportsman 4 11-12-2011 12:45 PM
rotopax question gasman442 ATV General Discussion 8 07-30-2011 05:51 PM
Rotopax fuel pac 4x4guy ATV General Discussion 12 04-06-2011 03:07 PM
RotoPax Mounts 09 Sportsman ATV Parts for Sale 0 09-12-2010 06:22 PM
Rotopax Cableguy657 ATV Visual & Body Modifications 3 07-25-2010 01:40 PM
