New CDI and machine is now not running right
I ordered a new CDI box because I could no longer use the kill switch or key to shut the motor down. I had just been using the ground wire off of the old CDI unit that plugs into the "triplet ground" (speedometer, kill switch, and i think key) and grounding it to the frame to kill the motor. I decided to replace the unit so everything would function correctly. However now that everything is plugged back up the way it should the motor cranks fine, will shut off with kill switch and key but when you rev the motor past idle it sputters, backfires, and then shuts off. I am lost! The switch that controls lights, kill, start and override is new and was installed by Polaris tech. Please somebody tell me what I need to do.
