01-31-2012, 06:23 PM
Member #21325
500 HO timing
I think my motor has jumped time the exaust is sucking instead of blowing out, have good fire and getting fuel. how is this checked???
03 Polaris 500 HO 2" lift
(28 Mudzillas, snorkels,
big bore kit)
04 Polaris 500 HO 2" lift
(28 Mudbugs)
07 Polaris X2 500 HO 2" lift
(Winch to pull the others out)
Ride with NDC Trailriders
01-31-2012, 08:16 PM
02-01-2012, 01:49 AM
Member #1234
you'll need to remove spark,plug,valve cover and timing inspection bolt (it's on the rope pull cover on top). Using the rope pull,Set engine to top dead center,using the marks on the flywheel, there should be two dots on the cam gear and they should be paralell with the top of the head . Inspact cam lobes for wear and adjust valves(all 4 of them at .006")
02-01-2012, 03:34 AM
Member #7294
What year machine do you have, the older 500's had cam problems.
02-01-2012, 04:19 AM
check the cam
02-01-2012, 01:46 PM
Member #21325
It's an 03 HO, a friend of mine did his valves a while back and is going to help me with mine this weekend, thanks for the replys.
big bore kit)
(28 Mudbugs)
2000 polaris 500 ho timing, how to adjust the timing on a polaris 500 hoo, how to adjust timing 500 polaris 500, how to adjust timing on polaris, how to time camshaft on a polaris 500ho, polaris 500 ho timing, polaris 500 timing, polaris 500ho big bore, timing 500 polaris, timing for 500 ho
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
how to set timing
hershell973 |
Polaris Magnum |
1 |
01-29-2011 06:54 AM |
timing
johnnyjaws |
ATV Repair and Maintenance |
0 |
10-05-2010 04:51 PM |
05 Predator 500 timing
cooley1 |
4 |
10-03-2010 12:29 PM |
500 EFI timing?
uncre8tv |
Polaris Sportsman |
10 |
03-21-2010 08:42 AM |
timing
shanechatter |
Polaris Sportsman |
5 |
01-18-2010 03:35 PM |
