hows it going/I have 2007 sportsman500 touring my atv is well maintained just recently on the speedo cluster where my it shows my fuel after a day out it starts flashing off an on telling me i'm out of fuel which is not true usually have about a tank could any one help me out on the problem I have Thanks Wazi
Sounds like you may have a bad sending unit. If you own an Ohm meter it's pretty easy to test. Hook it up to the 2 prongs on the right of the plug and it should go from 5-90 as it goes from empty (bottom) to full (top).
