Old 02-06-2012, 01:41 AM
Klimbimm's Avatar
Member #9738
Question
I have been experiencing a disturbing wobble in the right front wheel when I get it up to the 40-43 mph range. We are able to drive on the roads where I live so it's not like I'm blasting down a rough trail at these speeds. This is occurring on the highway where the speed limit is 50 mph. I don't see anything wrong with the wheel or tire. Pressure is 5 psi in the front and 4 psi in the rear.
The wobble is quite pronounced and it feels like I might lose control or catastrophic failure is imminent.
Anyone had an issue like this? Any thoughts?
2011 Sportsman EPS 550 touring
Klimbimm
2011 550 Sportsman Touring EPS
ATV Guru Cobra Front Brush Guard
Ricochet Everything Guards
Polaris Winch
Glacier 3 Plow System
Old 02-06-2012, 03:50 PM
mowman's Avatar
Member #22713
Could be a bad wheel bearing or something bent in front suspension. I would get it checked out by a mechanic.
2011 Sportman 500 HO - RedRocket
2011 Sportsman 400 HO -GreenHornet
Love to Live ...Live to Ride....Polaris
Old 02-06-2012, 03:53 PM
Kevcules's Avatar
Member #14887
Not trying to insult you but are your wheel nuts tight? A bad wobble should reveal something way out of whack.
Kevin
Old 02-07-2012, 01:45 AM
Klimbimm's Avatar
Member #9738
Not Insulted At All
Actually I can't remember if I checked the lug nuts so I'd better do that to be sure. Don't see anything bent in the area either.
Klimbimm
Polaris Winch
Old 02-07-2012, 03:37 AM
SNW629's Avatar
Member #1414
check the front end for anything loose,if you find nothing then take both front tires to a tire shop and have them spin on a balancer to check for out of round tire and bent wheel.
09 850XP EPS
RT30 WARN WITH KFI MOUNT
Old 02-07-2012, 11:17 AM
Grassman's Avatar
Member #22623
Bearings would be my first guess, provided tires and lug nuts are good.
Old 02-07-2012, 06:17 PM
bakada's Avatar
Member #2821
I had a bad wobble at high speed and after checking everything over I took the wheel into a tire shop to see if they could balance it. It was out by 8 ounces and they wouldn't balance it. I had them take off the tire and try to spin it on the rim to see if it could get a better weight distribution. Found it full of slime. It was cold and the slime wasn't spreading out like it does when its warm. Even when its cold it will eventually spread out and the wobble diminishes.
2003 polaris 500 front wheel wobble
polaris sportsman 550 touring tire psi
sportsman 700 bad wheel bearings
2003 Sportsman 500 Vin Question & Wheel Bearings Question jeffh141 Polaris Sportsman 2 07-16-2011 07:34 PM
