Just curious i have 11 850xp eps , and when looking at aftermarket stuff it seems alot it only goes up to 09-10, is there any difference, i was looking at skid plates, lift kits, stick stoppers, etc.... is there alot of 11 stuff out there?
Rear suspension, lower front fascia, battery location, and front rack mounting clips are different between 2009-2010 everything else is the same.
Between 2010-2011 they changed the EPS to be configured differently to get a larger gas tank in there, and went with smaller axle diameters, and beefed up the rear A-Arms a bit to strengthen them. They also moved the clutch air intake to the rear of the machine instead of the front. Engine, tranny and suspension geometry all stayed the same for 3 years.
2012 is the new HO throttle bodies, and larger airbox. Not sure about other changes on the 2012.
