Old 02-08-2012, 08:31 AM
Dan500's Avatar
Member #23059
500 Sportsman Polaris rear axle
We took our 500 in to get a boot put on the rear axle. We went out riding that week-end and the axle came completely out. Does any one know if this can happen on its own or if it is possible that they forgot to put the clip back in.
Old 02-08-2012, 09:58 AM
Dan500's Avatar
Member #23059
No one out here know the answer to this?
Old 02-08-2012, 10:04 AM
maverick11's Avatar
Member #3694
Did it come out of the tranny or the hub?
Old 02-08-2012, 10:05 AM
Dan500's Avatar
Member #23059
The tranny
Old 02-08-2012, 10:13 AM
maverick11's Avatar
Member #3694
I have never pulled the rear out put I think (and someone correct me if I am wrong) but I think it comes out the same as the front. It may just not have been set back in enough to grab the set ring. I could be wrong though. Hope it didn't destroy anything to bad.
Old 02-08-2012, 11:13 AM
Dan500's Avatar
Member #23059
thanks, we hope not.
Old 02-09-2012, 07:12 AM
Dan500's Avatar
Member #23059
When removing and replacing the axle on a 500 sportsman Polaris do you have to change that inner clip and if you don't could that cause the axle to pop out on its own.
Old 02-09-2012, 07:55 AM
maverick11's Avatar
Member #3694
I know they recommend it on the front. But I don't unless it looks bad. Its like a cotter pin, if its not bad, I will just reuse it. But that could have been your problem. A cheap fix.
Old 02-09-2012, 09:41 AM
Dan500's Avatar
Member #23059
this is on the rear and yes that is what we are thinking a cheap fix. But the whole axle came out and we didn't know it and had to ride back to camp. Hoping it didn't screw up the insides of the teeth.
Old 02-09-2012, 04:10 PM
Grassman's Avatar
Member #22623
I'd find a different mechanic next time.
2010 polaris sportsman 500 rear end
2012 polaris sportsman 500 rear axel
500 sportsman rear driveshaft removal
98 polaris 500 rear axle
98 polaris sportsman 500 rear axel upgrade
98 polaris sportsman rear axel
how ro remove rear axles on polaris sportsman 500
how to pull a polaris rear axle
how to remove back axle on polaris 500 sportsman
polaris rear axle 500 sportsman
polaris rear axle assy
polaris rear axle parts
polaris sportsman 500 rear axle
polaris sportsman axle falls out
pullin a rear axle 06 sportsman
rear axle for a polaris sportsman 500
removing rear axle on polaris sportsman
removing rear axle polaris sportsman 500
sportsman 500 rear axle remove
sportsman axle comes out
polaris 6x6 rear axle spacing mactuff Polaris Sportsman 2 07-13-2011 05:31 AM
2001 polaris 250 rear axle bearings HELP PLEASE 2001 trailblazer ATV Repair and Maintenance 2 05-03-2011 06:01 PM
03 sportsman 700 REAR AXLE HELP!! jmartin ATV Repair and Maintenance 0 09-20-2010 07:53 AM
WTB: 1998 Polaris Sportsman 500 Rear Axle scbass203 ATV Parts for Sale 1 08-09-2010 04:05 PM
98 polaris sportsman rear axle soxfan68 Polaris Sportsman 3 02-20-2010 09:15 AM
