Old 02-08-2012, 02:26 PM
twaskom's Avatar
Member #23049
Question after hearing about oil in air box
I was reading about someone getting a new 850 touring model. A comment was made about hoping the problem with oil in the air box was fixed.
I am looking at getting a used 800 touring and want to know if this problem applied to the 800 and if so would like some more information about what exactly the problem is.
thanks in advance for your help
Tom
Old 02-08-2012, 02:56 PM
ZPO's Avatar
ZPO ZPO is offline
Member #21790
Oil in AIrbox links
Here's the thread:
http://www.polarisatvforums.com/foru...irbox-fix.html
(Scroll down to the last couple of pages to see the fix)
Found the other thread as well here:
oil in air box
Basically the 2012's have some redesigned parts that will correct the problem if you experience it.
2011 Sportsman 850 X2 LE Sage Green
bobx2's Avatar
Member #14376
Not a problem in the 800. No worries there.
Old 02-08-2012, 03:00 PM
ebaysnyper's Avatar
Member #13772
Send a message via Yahoo to ebaysnyper
This is why i said to avoid the 850.
Sent from my DROID3 using Tapatalk
2007 sportsman 500 x2 efi
26" sadona ripsaws on 12" itp ss312's
3 headlight mod relay type
2500 Ib polaris winch
custom made "winch saver"
custom work light mod with lighted switch and 18 Watt lamps
custom stealth black shock covers
Front trunk locks Polaris Part #2874548 $7.50 each @ dealer
front rack rails converted to "U channel" strut for easy attachments
pure polaris HD front springs
Old 02-08-2012, 03:16 PM
twaskom's Avatar
Member #23049
Thanks everyone for the information. I am looking at an 08, 800 so I will not be affected by this problem. I have been reading about how well the 800 / 850 like fuel. I am guessing I should have a fuel pack or two.
I am not at all worried about the cost for the fuel usage, just wouldn't want to run out when I'm on the back 40. It seems like most recommend the roto pack as the container of choice.
Again thanks for the quick response
Tom
As said, does not apply to the 800. Completely different...no worries.
Old 02-14-2012, 04:05 PM
jules's Avatar
Member #13329
the oil in the airbox just happends after your flipped your bike. because there is a tube that goes from your airbox into the transfer case. when you flip the bike some of the oil runs back into the airbox.
2011 Polaris Sportsman 800 EFI
4x4, polaris 2500 winch, itp wheels and mud lite tires,
polaris front and back rack, polaris tool box,
Polaris glacer III blow 55 inch,
Old 02-15-2012, 04:30 AM
Mystro's Avatar
Member #15977
Not on 850s. It just shows up there under normal driving conditions.
2010 Polaris 550 X2
aka..RRV "ricer recovery vehicle"
Polaris/Vision Rims w/ Vision trailfinder tires
Polaris extreme front / rear bumpers
Polaris winch, Heated grips/ throttle
GPS, LED aux lighting,
Ricochet A-arm Armour
Old 02-18-2012, 08:12 PM
RedScrammy's Avatar
Member #22537
i am fairly new and haven't found any info yet but this would help to explain why my 2010 scrambler lost close to half a quart of oil when she [almost] flipped ass over tea kettel on me today, or is that too much oil oss for that. I just did the first oil change on it yesterday and did a fairly high speed ride today, not sure how well broke in the atv is yet but the dealer told me after the first tank so that is what I went with. Could it have been too soon and i had that much blow-by?
sorry for the rambler thank you in advance
2010 Scrambler 500 HO-Moose Full Chassis Skid Plate, Moose A-Arm Gaurds, RSI 4" Rise Handlebars, Moose Flex Handgaurds, K&N Air Filter
1995 Scrambler 400 4x4-DG Alloy Series front bumper, OURY purple grips, UNI Two Stage Foam air filter. Soon to have Xplorer trans. swap and 26" P.X.T. tires
1995 Storm 800-PSI Triple Pipes, SLP Ultra Lite skis, V-Force 3 Reeds, cut and rechambered heads, ported and bored carbs, RSI 6" rise handlebars, 1.25 Camoplast Ripsasw
1975 Chevy Custom Deluxe 20- 350SB, Edelbrock carb and intake, headers with true daul straight pipes, 4 speed manual, 4" lift, 33" Super Swampers(will be 35" or 42" very soon, have a set of both but need to convert the front hub to 6 bolt to fit 15" rims) Billet grille
oil in air box sportsman 500
oil in airbox on sportmsan
polaris 500 oil in airbox
polaris 800 sportsman oil in air box
polaris oil in airbox
polaris sportsman 500 oil in airbox
polaris sportsman oil in airbox
2003 Sportsman 500 Vin Question & Wheel Bearings Question jeffh141 Polaris Sportsman 2 07-16-2011 07:34 PM
hearing a loud "clack" when i let off? highdesert Polaris XP 18 02-12-2011 06:37 AM
