Old 02-09-2012, 11:58 AM
we7889's Avatar
Member #23096
Talking EPI clutch kit install
Just installed an EPI clutch kit in my 2011 500 HO touring. I talked to 2 tech's from EPI very helpful. I was told to skip the secondary spring due to the touring models having a heavier spring in it already due to the extra expected weight. So I only did the primary. I put in 47gram weights ( now I'd like to try the 50's) and the red spring they suggested. That only took me back to stock. (The reason for the kit, I put on Sedona aluminum rims and Dirt Devil 26",s) So, I took it upon myself to install a silver spring, 35# for red, 50# for silver, subtle change but big difference in performance. (only wants to try to raise the front tires but can't- that's why I want to try the 50gram).No aftermarket manufacturer has a clutch kit out yet for a Polaris touring. I guess were excluded when it comes to wanting to beef us up. And an, oh yah! screw the clutch puller! Just remove the belt and replace the parts.
Old 02-09-2012, 04:36 PM
Old 02-18-2012, 07:51 PM
4wheelindad's Avatar
Member #22913
hey we7889, I'm new to the Polaris ATV's. I've seen a lot of posts about the EPI clutch kits. What kind of performance improvements do they make? I don't want to pop wheelies or anything, but if I can improve performance without breaking things, I'm all for it. My '04 700 Sportsman is all stock, but I've added a rear seat and it has 26" tires. I think stock that year are 25's. I will be mostly trail riding and going thru a few mud holes. Any info will be helpful.
'04 Sportsman 700 EFI
Warn RT 25 winch w/ KFI mount
3 headlight mod
Kimpex outback ATV trunk w/ seat
Kimpex rear fender guards w/ foot pegs
Old 02-21-2012, 10:06 PM
RENOBADBOY's Avatar
Member #23274
EPI red spring and fly!!!
Old 02-22-2012, 05:44 AM
Buzzie's Avatar
Member #19891
How difficult is it to install a new epi clutch kit? Where is the place you found best to order from?
Wheeler-2007 Polaris Sportsman 800
2001 Yamaha Raptor 660
Hauler-2003 Quad Cab Silverado 1500HD
Trailer-16x7 tandem axle trailer
Old 02-23-2012, 11:53 AM
we7889's Avatar
Member #23096
Epi
I called EPI directly and talked to a tech. No one was listing a clutch kit specifically for a touring. For mine I found the silver spring and 47 gram weights seemed to pull better than using the red spring.
Old 02-23-2012, 12:03 PM
we7889's Avatar
Member #23096
It wont pull a wheelie, comes close. It just has a better pull through out excelleration.
Old 02-23-2012, 12:05 PM
we7889's Avatar
Member #23096
Watch the you tube video. Dont bother pulling the primary do it right on the machine. I just pulled the belt.
2009 polaris rzr epi clutch kit install
best belt recommended for clucth kit polaris rzr 800
clutch kit install rzr 800
epi clutch instal
epi clutch kits polaris forums
epi red spring install
how to put a starter clutch on polaris 50
polaris 700 wheelie after clutch
polaris epi clutch kits
sportsman 800 pulls wheelies after epi clutch kit
sportsman 800 wheelie with epi clutch kit
what is a epi clutch kit?
wheelies on sportsman 800 with epi clutch kit
EPI Sportsman clutch install cwlongshot ATV Performance Modifications 3 04-17-2011 03:48 PM
High Lifter Clutch Kit install Gator Pit ATV Performance Modifications 0 03-26-2011 06:23 AM
2010 xp 550 clutch kit install chad1926 Polaris XP 1 01-23-2011 07:47 PM
started clutch kit install and found this....... QuickSilver74 Polaris Sportsman 6 01-05-2011 03:15 AM
I want to install heelclicker clutch kit in 2000 SPMN 500, is this a good choice? JOHN 3:16 Polaris Sportsman 6 01-28-2010 08:45 PM
