02-17-2012, 01:26 PM
Member #23324
Requirements for Black Hills Trail Riding
Does anyone know the actual requirement for a horn for trail riding in the black hills. Does it have to be a mounted horn or will a handheld air horn work?
02-17-2012, 01:55 PM
Member #23207
I didn't even know there was a requirement for the Black Hills...we are planning on going there this summer. Where did you see this requirement?
2012 Can-Am Outlander 1000XT Black
2012 Polaris 850HO XP EPS Sunset Red
(3) 2011 Honda Recon ES
02-17-2012, 02:35 PM
Member #23324
Horn Requirement
I found it in the DNR website for South Dakota. They require a mirror, Horn and Brake lights
02-17-2012, 02:55 PM
Member #23207
Thanks...
02-17-2012, 10:07 PM
Member #9235
If their regulation is like Montana's, it has to be a hard wired horn. A squeeze bulb or horn in a can won't cut it. You'll have to check it out.
02' Sportsman 500 HO
Warn 25XT + Bumper
25" Grim Reapers
GoldFinger left hand throttle
and other stuff...
02-18-2012, 04:12 AM
also need an Orv sticker from south dakota or wyoming
02-18-2012, 06:04 AM
Member #23324
I knew about the registration sticker but having to hard wire a horn on all the wheelers sucks
02-18-2012, 06:18 AM
actually I like mine, when your riding with other people you can get close to them and honk the horn and they will hear it and stop if you want them to, you can get their attention. I bought a small car horn from O'reilly's for like $15 dollars, it fits in the headlight pod on the 850, there is a hot wire to cig lighter right there, used a spring loaded toggle switch , had to drill hole in lower part of headligt pod, bet I didnt use much over 1 ft of wire and a few crimp on ends, prettyy simple works very well, horn and wiring in and up away from moisture
02-18-2012, 06:39 AM
Member #23324
Good to know. Thanks for the info!
04-22-2012, 09:13 PM
Member #12643
I have never heard of a mirror, horn, or taillights being required to ride in the hills, only to be street legal. Now the sticker is required to ride certain numbered trails.
2003 Polaris Predator 500, FMF Power Core 4 full exhaust, K&N drop in filter
2000 Polaris Sportsman 500
2011 black hills atv trails, atv air horn, atv riding black hills, atv riding in black hills, atv riding in the black hills, atv trails black hills, atv trails in the black hills, best atv trails in black hills, black hills atv forum, black hills atv riding, black hills atv trail, black hills atv trail riding, black hills atv trail system, black hills atv trails, blacks hills atv trails
