Gravel Drive Grader? - Polaris ATV Forum
Old 03-07-2012, 05:32 AM
pavwa's Avatar
Member #23787
Iam interested in getting a box scraper or a blade or something to loosen and grade a large packed down drive and parking area. What do you guys use? What would work the best? will spend some cash on a unit but don't want to get crazy...Any info or opinions would be great, Thanks
Old 03-07-2012, 07:46 AM
Maxpolaris's Avatar
Member #22796
I'm all ears on this too.
I have a section of cyclone fence I use for a drag but it has to be weighted evenly.
Works ok but it doesn't want to stay centered behind my atv...
2012 550 X2, winch & plow, stock and ready to rock
Old 03-07-2012, 08:33 AM
itsfit's Avatar
Member #1726
I think Koplin make a drag that you put cinder blocks in...
2008 Sportsman 500 HO Polaris winch, front and rear bumpers, rear rack extender, ricochet armor
Old 03-07-2012, 09:03 AM
zoomeroo's Avatar
Member #18920
DuraGrade - A1 Box Scraper for Garden Tractors or ATVs and Quads, Requires No Three Point hitch
This is just one of many brands. Get one that has wheels on the back.
I browsed "atv grading box"
I have a big one that is 6' wide on a TN65hp tractor.
Old 03-07-2012, 09:08 AM
CVCOBRA1's Avatar
Member #23146
Agri-Fab Box Scraper Blade — 42in. Width, Model# 45-02651 | Box Blades | Northern Tool + Equipment
Here's a light version. Northerntool has better ones but they are all 3 pt. hitch models.
Old 03-07-2012, 09:34 AM
pavwa's Avatar
Member #23787
I wonder what the difference is between the $1200 compared to the $300... That is a huge price difference so it makes you wonder. There cant be that big of a performance difference, maybe weight but that can be adjusted. I dont know what to do, hate to throw away $300 on junk or $900 extra on something not needed.. decisions decisions... I found a bunch more but wanted to see if anyone had any experience with any. Thanks
Old 03-07-2012, 09:47 AM
CVCOBRA1's Avatar
Member #23146
From what I can see is the $300 one has no wheels. It is a "weight only" scraper....you wont have much control over the digging capability. The $1200 one has wheels with a 12V electric motor and screw drive that you can control depth with. Not sure how you would even transport the cheap one unless you just pull it backwards.
Old 03-07-2012, 09:59 AM
Clinebo's Avatar
Member #9235
The guy who owns a trailer court near me bought one of these.You can get a free DVD from them that shows it in action.
DRŪ Power Equipment - Power Driveway Grader - for dirt driveway, dirt road, and gravel driveways maintenance
2002 Sportsman 500 HO
Warn 25XT + Bumper
25" Grim Reapers
GoldFinger left hand throttle
and other stuff...
Old 03-07-2012, 03:09 PM
RENOBADBOY's Avatar
Member #23274
I made mine with heavy angle iron and expanded metal. I got 2 old engine blocks for weight. Welded chain to both sides and slide it over the ball. I use a nut and bolt to put an angle to the slide. Has worked for me for the last 4 years fine!
Old 03-07-2012, 08:04 PM
Talon's Avatar
Member #23484
A friend of mine had a piece of I beam and then a section of chain link fence attached to the back of the I beam and then a 2X8 on the other end of the chain link, it worked pretty good, but he was pulling it with a truck. I guess if you could find a smaller size piece of scrap I beam it would work behind an ATV. His was from a old house I beam. We used it to smooth out our go cart track before we watered it down.
Craig
2011 850XP EPS, Roctane tires, 3000lb winch
2013 850XP LE, Glacier III Plow
atv driveway grader
atv grader
atv grader attachment
atv grader blade
atv graders
atv gravel grader
atv road grader
box grader for atv
driveway drags for atv
driveway grader for atv
driveway graders for gravel driveways
pull box blade for 4 wheeler
2 wheel drive to 4 wheel drive trouble carpenterkerry Polaris Sportsman 5 02-20-2012 11:45 AM
scrapping front wheel drive on 2001 325 shaft drive Kiwikiwi Polaris Magnum 3 02-08-2012 10:11 PM
How to drive using the ADC zoomeroo Polaris Sportsman 18 11-17-2011 05:11 PM
XP Winch and Plow/ Grader blade ohchevy ATV General Discussion 0 09-20-2011 04:43 PM
drive cog mistertubby2 ATV Parts Wanted 2 08-08-2011 05:58 AM
