Old 05-21-2012, 03:53 PM
Lawson89's Avatar
Member #26461
Question Clicking or clacking noise
Does anyone know of the clicking or clacking noise u hear when braking or going down hill sometimes mostly the back foot brake any explanation??? It's a 2012 sportsman 400
Old 05-21-2012, 07:38 PM
Lawson89's Avatar
Member #26461
Well no one has said anything so that's not good I reckon better get her to the shop
bone stock 2012 polaris sportsman 400 h.o new to polaris making a test run lol
Old 05-21-2012, 08:13 PM
Amdforever's Avatar
Member #26260
A little more detail? is this noise occurring only when the brakes (front or rear or both?) are engaged? Does it just do it one time and stop or is it constantly "clicking"? Does it sound metallic? Which end of the quad does the sound seem to originate?
I'm no mechanic by any stretch of the imagination but it could be anything really unless you can pin point to particular areas and type of sound. Could be a loose plastic piece, loose heat shielding, loose cable, a suspension click as it settles under the G's of braking, or the brake pads clicking on the rotors if yours came with holes drilled in them like the 850s. Gotta do some Sherlock Holmes stuff for others to help ya out
Old 05-21-2012, 08:23 PM
Lawson89's Avatar
Member #26461
It's defiantly met talc it sounds to me that it's coming from the center of the machine up under it I think it's slack in the drive train it clacks pretty bad usually when braking with any brake or turning ( while rolling and throttle not engaged )I called my dealer and they said they all do it but no one else seems to know what I talking about and I've also had ppl tell me that the 2012 have been coming out the crate with bad axles just wanting to c what I can find out before I go argue with my dealer lol
Old 05-21-2012, 08:33 PM
Amdforever's Avatar
Member #26260
Hmm, let's see what others can think of and suggest.
Old 05-21-2012, 08:37 PM
Lawson89's Avatar
Member #26461
Red face
Ok I'd really like to know if anyone else has a 2012 sportsman400 ho doing this if not I need to start the fight with the dealer lol
Old 05-25-2012, 11:50 PM
krankie's Avatar
Member #20618
My 500 does the same thing.The dealer says it is drive line "lash" and I shouldn't worry.
Old 05-26-2012, 12:39 AM
jordaman17's Avatar
Member #13240
yes your probably hearing the slack in the drive train, very common.
5140km 2008 Polaris Sportsman 500 Ho, Polaris Hand & Thumb warmers, RotoPax 4 Gallon Fuel Pack, Custom Made Rear Bumper, PowerMadd Hand Guards, Polaris Rear Work Lights, Ricochet Ultimate Armor, Modified Stock Muffler, Polaris 3500lb Winch, Rear Rack Extender, Super Atv 2" lift kit, Polaris Brush Guard, 3 Headlight Mod, Uni Air Filter, EPI 'patv1' primary clutch spring. All up on Interco Swamplites! Maintenance is the key to a never ending happiness
Check out my youtube channel! ---> http://www.youtube.com/user/mudsling...ew=0&flow=grid
Old 05-26-2012, 05:36 AM
mowreyj's Avatar
Member #24191
12 400
my uncle has one and it does the same thing its drive train lash
02 500 sportsman x
warn 2500 front-back winch
2 inch lift
heated grips
customized muffler
heat wrap pipe
2 halogen beams
tamarack passenger pegs
HERS
99 350 Big Bear
14" SS wheels
ITP baja cross 26" tires
Kolpin fr.-Back bags
thumb throttle extender
custom exhaust
3" additional lights on front
Old 05-26-2012, 07:15 AM
gtsum2's Avatar
Member #23200
when decelerating over bumps or when going downhill without throttle, you will hear the driveline making noise. These are not quiet machines by any stretch of the imagination. Now, if you heard a clicking sound from the axles, then chances are your CV joint is out of grease and possibly bad (happened to me once).
2000 polaris sportsman 500 clicking noise deceleration
2011 polaris ranger 500 for by for making noises regarding from front wheels or suspension
2012 polaris 500 clicking noise when braking
2012 polaris 800 poping noise#gsc.tab
2012 polaris ranger 500 noises
2012 polaris sportsman 500 noise in rear
clicking in my 2012 500 polaris when slowing down
knocking noise on a 2012 polaris ranger
polaris ranger 500 has a tapping noise
polaris ranger clicking noise
polaris ranger clicking noise when going downhill
polaris rzr popping noise going downhill
rzr4 suspension clunking noise
sportsman 400 makes a clicking sound when braking
sportsman 800 makes a clicking noise when braking
2012 500 ho clicking noise fourbyfour ATV General Discussion 30 03-12-2013 03:15 PM
'09 sportsman 500 clicking noise cdwladr ATV Repair and Maintenance 3 04-30-2012 04:17 PM
Clicking Noise In Reverse? jac42779 ATV Repair and Maintenance 5 01-21-2012 04:26 AM
Clicking noise from rear end. gramslam05 ATV Repair and Maintenance 5 12-01-2010 02:09 AM
Clicking noise by starter bighaas ATV Repair and Maintenance 1 09-08-2010 05:57 AM
