06-26-2012, 11:03 PM
Member #24191
2002 front hub Question
Can I use pure Polaris( Demand Drive Plus )in the front hubs the Lube chart says
5oz.On you tube i watched a vid that shows filling it to the 4 oclock position but Im unsure if this is the correct fluid, On the bottle it says use in place of LT Fluid, ADC Fluid and Demand Drive Fluid *not designed to replaced Angle drive fluid Can somene please tell me if i can put this in the front hubs if not what shoud I use ? Thanks in Advance
Jamie in AZ
02 500 sportsman x
warn 2500 front-back winch
2 inch lift
heated grips
customized muffler
heat wrap pipe
2 halogen beams
tamarack passenger pegs
HERS
99 350 Big Bear
14" SS wheels
ITP baja cross 26" tires
Kolpin fr.-Back bags
thumb throttle extender
custom exhaust
3" additional lights on front
06-27-2012, 06:03 AM
For your hubs yes, the Demand Drive plus is the recommended fluid for your hubs. Polaris basically consolidated the LT fluid, and the ADC fluid into one, and that is now the Demand Drive Plus.
It is still separate of the angle drive fluid.
But for your hubs, Demand drive plus it is!
06-27-2012, 06:40 AM
Member #5074
Demand Drive Plus it is. Capacity is small, my manual says 2.5oz. Fill to 4 or 8 o'clock position.
2001 Sportsman 500HO
Rear drop rack
2000lb winch
No mods
06-27-2012, 11:20 AM
Member #9235
E-mailed you about this ....
Pack of 3 8 oz. Storage Bottles With Twist Caps
I use one for filling my hubs,one for distilled water for the batteries,and have one as a spare for now.
02' Sportsman 500 HO
Warn 25XT + Bumper
25" Grim Reapers
GoldFinger left hand throttle
and other stuff...
06-27-2012, 12:12 PM
Member #24191
thanks for the info Guys
I changed out my hub fluid the old stuff was really black and nasty allen plugs had a little bit of stuff on the magnets but Im good to go now gonna run it for a mile or so and recheck levels
02 500 sportsman x
2 inch lift
heated grips
customized muffler
heat wrap pipe
2 halogen beams
HERS
99 350 Big Bear
14" SS wheels
custom exhaust
06-27-2012, 08:27 PM
Member #9235
The hub fluid is always the blackest of all the fluids when I service mine. I'm going to start changing it twice a year now instead of annually.
Warn 25XT + Bumper
25" Grim Reapers
and other stuff...
01 sportsman front angle drive fluid, 2001 angle drive fluid, 2002 polaris magnum 500 awd fluid, 2002 polaris the front hub is loose, can i use demand drive plus for 99 sportsman 500, does the front hub on atv require fluid, goldfinger left throttel in you tube, how much demand drive fluid in a polaris 500 magnum, how to check oil in 2002 poliris front hubs, how to fill oil for the front hubs on 2002 polaris sportsman 500, polaris 2001 500 sportsman angle drive, polaris demand drive plus, polaris front hub drive fluid, what lube for front hubs 2001 polaris magnum, youtube how to tell if front hub is bad on atv
