Locking front differential? - Polaris ATV Forum
Old 07-11-2012, 12:17 PM
Mark 800's Avatar
Member #14423
I have a 2007 800 Sportsman that I bought a couple years ago. GREAT running machine and Iíve put a bunch of hours on it riding trails, swamp and working on the farm. Itís always been tough to turn. I didnít realize how tough it was until I started riding other machines. I bought my wife a 450 Yamaha Kodiak and it has a ďlocking front differentialĒ option. It turns on a dime when that option isnít engaged. Iíve rode my buddyís 650 Arctic Cat and it turns much tighter and with less effort than mine (although my ride is MUCH better!) I didnít get an ownerís guide, but did purchase a shop manual. Itís home and Iím not. Iím sitting here wondering if Iím missing an easy option to turn off the front locking differential. Does anyone know if I have that option hiding in the buttons?
Old 07-11-2012, 12:25 PM
nicks500HO's Avatar
Member #4101
I don't believe there is a locking diff option on any year sportsman. Maybe your front diff is all messed up or your speedo is goin. I believe the speedo controls awd.
2004.5 Sportsman 500 HO
SS 108's wrapped in 26" XTR'S
K&N Filter
SPX Hand/Thumb Warmers
2500# Warn
Engine Ice
Awaiting Install....
RDC Rad Relocate kit
Custom Snorks
More RDC To Come....
Old 07-11-2012, 01:50 PM
Your AWD is not working properly. Sounds like it is always engaged. Your machine should stay disengaged until the rear wheels slip. Meaning, in AWD, it should turn even easier the the "locking front diff" option because when the front diff is unlocked, it's still in 3wd. It's an inferior system to what Polaris uses.
You need to chase down the reason why it sounds like your 4x4 isn't disengaging.
Old 07-11-2012, 02:03 PM
Lollygagger77's Avatar
Member #19655
I blew the rear seal on my front diff, so after a while the fluid would leak out and it would fill with dirt and mud, and then when I would take off it would just engage the AWD at any acceleration. Once I replace the front diff it was all good (got it from Babbits online for 40% less than my dealer was trying to charge) So I would change your fluid and make sure it looks good and clean, if it does then you may have other issues, if not change it out (not cheap). I do recall my 800 took elbow grease turning too but on the trails with AWD on or off there was not much difference...
NEW ADDITION: 2016 RZR 900S w/EPS
2012 Polaris 850 XP HO w/EPS
-28" Terminators
-HD Springs and JCCAPRI bushings
-QSC Clutch kit
-3500# Polaris winch with Synthetic Rope
-Polaris Front Brush Guard
-Polaris Lock n Ride front and rear storage
-Polaris Mid Lock n Ride Windshield (smoke)
-60" Warn ProVantage Plow
-Symtec Hand Warmers
-Quadrax Rear seat w/foot rest kit from ATVSUPERSTORE - Square Tube
Old Machines:
2006 Sportsman 800 EFI, 2005 Sportsman 700 Carb, 2004 Sportsman 500HO Carb, 2000 Sportsman 500 Carb
can i put a locking differential in the frontbof my polaris sportsman 800
does polaris atv have a locking differential
does polaris sportsman 570 have diff lock
polaris differential locking up
polaris locking differential
polaris ranger differential locking up
polaris ranger front locker
polaris ranger locking differential
polaris ranger locking front differential
polaris rzr locking diff
rzr 900 xp front end lock up
warn front differential locker for atv
front differential vwboomer ATV Repair and Maintenance 0 02-26-2012 06:42 AM
325 magnum front 4x4 locking issues. Need help firefighter439 ATV Repair and Maintenance 3 12-11-2011 10:22 PM
front wheel locking gordo1473 ATV Repair and Maintenance 2 03-02-2010 07:43 PM
I just put on the locking locks for the case up front. Bruce! ATV Visual & Body Modifications 10 01-30-2010 06:08 AM
1997 polaris 425 magnum front hub locking Alex ATV New Members 8 12-17-2009 04:17 PM
