Old 08-03-2012, 10:13 AM
400guy's Avatar
Member #28685
Polaris pulls to the right
My 2000 425 Expedition is pulling to the right. What would cause that?
Old 08-03-2012, 10:46 AM
kcaves's Avatar
Member #10305
Ur AWD is sticking, back up a little bit and see if it quits pulling
Old 08-04-2012, 07:00 AM
850HOTOURINGL.E.'s Avatar
Member #19390
Tire preasure.
Old 08-04-2012, 03:24 PM
Old 08-04-2012, 04:26 PM
IKEA52's Avatar
Member #14603
Good Day 400guy,
Check your toe alignment.
IKEA
Old 08-04-2012, 07:49 PM
400guy's Avatar
Member #28685
Thanks everyone! I'm thinking its a AWD issue.
Old 08-07-2012, 02:16 PM
Kalani938's Avatar
Member #20505
LoL, this happened to me the first day I bought my ATV, but it ended up being b/c the dealership forgot to put the right amount of air in my tires.
Red 2010 Polaris Sportsman 500 H.O.
ITP SS212 14" wheels with 27" Swamp Lites
K&N High Flow Air Filter
Old 08-09-2012, 07:48 AM
SOLOLUCKY's Avatar
Member #3193
My 330 did this, pulled to the left...weemd to pull harder when backing up..or at least thats when i noticed it pulling...turned out it was the Front CV joing was froze up...I took it out, disassembled it, greased it anmd reassembled, bought a replacement boot off Ebay form 10 bucks or so. ...Is good as new now...and was surprisingly easy to do.
Old 08-09-2012, 04:33 PM
gmiller0737's Avatar
Member #1628
Check or change your Hub Fluid, Get the proper fluid from a Polaris Dealer,To check remove allen head plug in Hub turn wheel till the Hub Hole is @ the 4 o clock position fluid should dribble out,If you don't remember when it was last changed just drain & refill the hubs to the proper level.
2011 polaris ranger pulls to the right
2012 sportman pulls to the right
4 wheeler 4wd pulls to right when backing up
causes for atv pulling right
my 08 rzr pulls to the righ in hard acceleration
my fourwheeler pulls to the right how to fix
polarias four wheeler pulls right
polaris atv pulls to the right sometimes
polaris pulling to the right
polaris pulls hard
polaris pulls to the right
polaris ranger pull hard left right
polaris ranger veers left
why does my polaris go right
why is my polaris ranger pulling to the right
'08 400 pulls a little to the right, normal? jpl20 Polaris Sportsman 7 11-06-2011 02:54 PM
Polaris sportsman 500 pulls hard right in reverse Atvrider22 ATV Repair and Maintenance 2 10-28-2011 09:02 PM
Sportsman pulls to the left devo Polaris Sportsman 8 06-26-2011 05:49 AM
pulls waybud ATV Repair and Maintenance 3 05-10-2010 04:11 PM
Pulls to left jimhubersr ATV Repair and Maintenance 1 09-17-2009 05:39 PM
