Tech support question of the week Sportsman 500 - Page 2 - Polaris ATV Forum
post #11 of 25 (permalink) Old 08-08-2013, 11:33 AM Thread Starter
Craig's Avatar
ketchemontherun, I have no idea why it happens, it appears to be a fairly rare problem. You will need a new cam, lifter and decompress spring and arm contraption, and obviously reset the valve clearances. Did your also blow a hole in the cover plate like mine did?
2013 Sportsman 550 LE EPS Stealth Black
Atv-Guru bumpers
Heated thumb and hand warmers
Lock and ride front and back boxes
Garmin GPS
Polaris Billet shift Knob
All Balls Ball Joints
P3ATV.com Bushings
Grim Reaper Tires
"Polaris STEALTH" bar
Craig is offline
post #12 of 25 (permalink) Old 10-28-2013, 08:33 AM
ronjearmy's Avatar
Same happenend to me
Mine blew a hole in the cover this weekend. If I could get the parts it looks easy to fix. I dont understand why you would have to replace the cam and rockers. Its just the dowell, release lever, spring and ball? Anyone know what it cost to have everything replaced?
ronjearmy is offline
post #13 of 25 (permalink) Old 10-28-2013, 10:07 AM Thread Starter
Craig's Avatar
If you look at the pictures I posted you will see that the dowel broke off inside the cam, if memory serves me correctly the little ball bearing had worn a groove into one of the rockers. So while we had it that far apart we decided to replace everything with new parts. I hope you where as lucky as I was and not out on the trail when it blew. I was taking mine off the trailer at home after a 4 day ride in West Virginia when it let loose. I considered myself lucky that I was not 30 miles from camp on the side of a Mountain when it happened.
Atv-Guru bumpers
Garmin GPS
P3ATV.com Bushings
Grim Reaper Tires
Craig is offline
post #14 of 25 (permalink) Old 10-28-2013, 05:18 PM
Never heard of such a thing. What year model was yours ronjearmy?
polman500 is online now
post #15 of 25 (permalink) Old 01-09-2017, 05:24 PM
Grimlin's Avatar
Just had the same thing happen to my 2000 500 magnum. Any idea what caused it? I was full blast in some trails and didn't notice till she started knocking .
Grimlin is offline
post #16 of 25 (permalink) Old 01-10-2017, 10:33 AM Thread Starter
Craig's Avatar
What causes the compression release to fail? That's a great question. The fact that your ATV is 17 years old and you are still driving it balls to the wall probably did not help. I'm not chastising you just stating fact;-). What I can tell you is that once the broken parts where replaced on my 2005 ATV (broke in 2010) it never had the problem again, I just got rid of that ATV about 6 months ago. I was lucky mine broke as I was backing it off the trailer one cold January morning so I only ran it with a hole in the engine for about a minute, so no engine damage from lack of oil. Wish I could be of more help but it's been to long ago to remember the fine details of what we thought caused the compression release to depart the casing.
Atv-Guru bumpers
Garmin GPS
P3ATV.com Bushings
Grim Reaper Tires
Craig is offline
post #17 of 25 (permalink) Old 01-10-2017, 02:05 PM
Grimlin's Avatar
Thanks. Yeah I am stumped, I just replaced the cam and lobes. The person before me used 10w-40. New tires, winch, warn bumper, belt and light bars, i guess i should of known some thing would break. hmmmm to rebuild or buy a ranger
Grimlin is offline
post #18 of 25 (permalink) Old 01-11-2017, 07:18 AM Thread Starter
Craig's Avatar
Rebuild the old girl, if you just replaced the cam and lobes it sounds like you will only need a hand full of not very expensive parts to get her up and running again, then buy a Ranger;-) Good luck!
Atv-Guru bumpers
Garmin GPS
P3ATV.com Bushings
Grim Reaper Tires
Craig is offline
post #19 of 25 (permalink) Old 01-12-2017, 06:16 AM
Old509cc's Avatar
Could you guys put up some pictures of the broken cams and decompression shafts? I'm curious what the ends look like where they contact the decompression ball.
My ride
1999 Sportsman 509
Rebuilt engine. R2C air filter. Block & tank heaters. QSC clutch kit in a QSC primary.
All steel grease-able tie rod ends. HPD steering bushing. 2" leveling kit.
25" Sedona ripsaws on 12" Badlands. Custom shock covers. Oury grips
Backup/work light. LED low beams. HID 35W high beam. Rev override switch delete.
Alba water temp, VDO volt, oil temp and pressure gauges. Cooling fan indicator light.
Hand and thumb warmers. Borla 14" Pro XS muffler. Custom prop shaft lock collar.
Dad's
2014 Sportsman 570 EPS
2500 Polaris winch. Polaris hand warmers. Lock and ride windshield. 60" Glacier plow.
Brothers'
2006 Sportsman 500 HO
Polaris 2500 winch. 24" box. Custom prop shaft lock collar.
2014 RZR S 800
Superwinch Tera 3500. Polaris roof, custom mounts. Pawltector parking brake.
Front & rear bumpers. Custom fire extinguisher mount. Rear diff pinion nut Torqued.
Faithful friends no longer with us
2004.5 Sportsman 500 HO.
2007 Rincon 680
Old509cc is offline
post #20 of 25 (permalink) Old 01-12-2017, 08:38 AM Thread Starter
Craig's Avatar
Old509cc, go to the first page of this thread you should find the pictures from several years ago of the parts you are asking about.
Atv-Guru bumpers
Garmin GPS
P3ATV.com Bushings
Grim Reaper Tires
Craig is offline
98 Sportsman 500 Question bsummers12 Polaris Sportsman 5 03-17-2011 06:58 AM
98 Sportsman 500 Question bsummers12 ATV Repair and Maintenance 2 09-23-2010 07:48 AM
Tech write ups for common repairs / issues / questions ? laterongc ATV Repair and Maintenance 4 01-23-2010 08:21 AM
Has anyone tried the Trail Tech Computer Kits? atvjunkie821 ATV General Discussion 0 12-20-2009 08:19 PM
07 Sportsman ETC question cfaas416 Polaris Sportsman 4 10-09-2009 06:43 AM
