Tech support question of the week Sportsman 500 - Polaris ATV Forum
Old 02-26-2010, 02:12 PM
Craig's Avatar
Member #3065
I recently had a Compression release failure where the lever release blew a hole in the cover plate that it resides behind on my 2004 Sportsman 500 which caused a massive oil leak, luckily I was in my driveway when it happened so no other engine damage was caused due to lack of oil. I am interested in finding out if anyone has seen this problem before, and if so what could have caused this to happen. My dealer who I know and trust tells me he has never seen it before and I can't find any post on the subject. I have already had the problem fixed which required a new cam, rockers and several other misc. parts. So I am more curious than anything plus I thought I would share this with all of you for informational purposes. I have attached several pictures for your review. Thanks Craig
Tech support question of the week Sportsman 500-100_2450.jpg   Tech support question of the week Sportsman 500-100_2451.jpg   Tech support question of the week Sportsman 500-100_2452.jpg   Tech support question of the week Sportsman 500-100_2456.jpg   Tech support question of the week Sportsman 500-100_2458.jpg
Old 02-26-2010, 02:38 PM
thanks for the detailed post. glad no further damage happened. 2.5 years parts and sales at a polaris dealer and i also have never seen this happen
Old 03-03-2010, 01:40 PM
Craig's Avatar
Member #3065
Blueline 15 thanks for the reply, looks like you are the only person who took the time to reply. I guess we are correct in our assumption that this is a rare issue. I have asked Polaris to comment on this topic as well, I will post thier reply if they decide I am worthy of a reply from them, cross your fingers.
Old 03-03-2010, 03:57 PM
atvjunkie821's Avatar
Member #2326
I have never seen it, so I didn't think I should reply. I have never seen it..
95 Magnum 425 4x4 , 518HO carb & air box, 12inch rear wheel conversion.
02 Magnum 500 RMK
Old 03-04-2010, 01:59 PM
Craig's Avatar
Member #3065
I have attached Polaris Customer services lame replies to my question below, it's really pretty sad that they won't forward the question to the technical department. I love the product but Polaris really needs to work on customer service!!!!!
Question: I recently had a Compression release failure where the lever release blew a hole in the cover plate that it resides behind on my 2004 Sportsman 500 which caused a massive oil leak, luckily I was in my driveway when it happened so no other engine damage was caused due to lack of oil. I am interested in finding out if anyone has seen this problem before, and if so what could have caused this to happen. My dealer who I know and trust tells me he has never seen it before and I can't find any post on the subject. I have already had the problem fixed which required a new cam, rockers and several other misc. parts. So I am more curious than anything plus I thought I would share this with all of you for informational purposes. Thanks Craig
Polaris Reply #1
Thank you for contacting Polaris Industries with this information. We do apologize that you experienced this issue.
Your dealer will need to contact their dealer services to find what if there have been other issues like the one you experienced. Here in consumer services we do not have technical information regarding the machines. We will document you comments and concerns for future reference.
Consumer Services
Polaris Industries, Inc.
Question: I don’t understand why you can’t simply forward my question on to the proper department. I am not asking for Polaris to pay for the repair I am simply bringing an issue to Polaris Industries attention, one that seems very rare. I have been a Polaris fan for many years and have personally steered approx. 30 people to purchase Polaris ATV’s over other brands (no kidding). I don’t want to go through my dealer on this, I want to deal directly with Polaris, I don’t think that is too much to ask. You know Honda makes a pretty good Machine as well.
Respectfully
Craig
Polaris Reply #2
Thank you for contacting Polaris Industries.
The reason we referred you to your dealer is because they have the contact with the correct department. Where here in consumer services we do not. This would be a technical issue and our technical information is only available at our dealers. We did state we will document your information and concerns.
Again thank you for contacting.
Consumer Services
Old 03-04-2013, 01:36 PM
sp50098's Avatar
Member #9372
craig maybe you or someone can explain to us how this system lowers the compression...i imagine it only lowers it at slow cranking speeds as to not steal power higher in the rpm range
Old 03-04-2013, 02:39 PM
Craig's Avatar
Member #3065
You are correct it only releases the compression at very low RPM's, the ball bearing on the cam rides on the lifter and the spring and counter weight work on centrifugal force so once the rpm's come up the ball bearing lowers allowing the valves to seat completely. At least that's my best guess on how it works.
Old 03-04-2013, 08:05 PM
Rooskey's Avatar
Member #22134
What is broken on the end of the camshaft? Looks to be a dowell. Is that the dowell that the timing chain hooks to?
2012 Sportsman 550 EPS Bronze Mist
2010 Sportsman 550 X2 Sage Green
2014 Sportsman 90 Sage Green
2006 Grizzly 125 Green
Old 03-05-2013, 08:12 AM
Craig's Avatar
Member #3065
Rooskey I have attempted to paste in a link to the exploded view of that part, if it does not show up go to babbits and look it up under intake and exhaust for the exploded view it should be part #15. No that is not what the timing chain hooks to it is purely for the compression release. 2004 Polaris A04CH50AQ SPORTSMAN 500 (A04CH50AO/AQ/AR/AS/AT/AV/AW/AX) Intake & Exhaust | Babbitts Polaris Parts House
Old 08-07-2013, 02:41 PM
ketchemontherun's Avatar
Member #13849
This just happened to mine yesterday...Uggg why would this happen???
2000 sportsman 500 compression
2000 sportsman decompression issues
2004 polaris sportsman 500 camshaft release lever
2010 polaris sportsman compression release diagram
99 polaris 500 compression
polaris atv tech support
polaris atv technical support
polaris compression release
polaris engine compression release
polaris sportsman 500 compression release
polaris tech support
polaris technical support
98 Sportsman 500 Question bsummers12 Polaris Sportsman 5 03-17-2011 07:58 AM
98 Sportsman 500 Question bsummers12 ATV Repair and Maintenance 2 09-23-2010 08:48 AM
Tech write ups for common repairs / issues / questions ? laterongc ATV Repair and Maintenance 4 01-23-2010 09:21 AM
Has anyone tried the Trail Tech Computer Kits? atvjunkie821 ATV General Discussion 0 12-20-2009 09:19 PM
07 Sportsman ETC question cfaas416 Polaris Sportsman 4 10-09-2009 07:43 AM
