Old 03-01-2010, 05:37 AM
LS1's Avatar
LS1 LS1 is offline
Member #3400
ATV Trailer (pull behind) question.
I will be fabricating a trailer for my XP's and my only issue is where to find spindle/hubs that will work with the Polaris bolt pattern. I have the factory takeoff wheel and tires that I will be using on the trailer, but i need a cost effective way to do so. I assume that I will need the polaris hubs from/for a quad, but what years have the same bolt pattern as the xp's?
If I can get all the parts, I will post up progress pic's in a pull behind trailer build thread.
2010 Sportsman 850 XP - EPS
2009 Sportsman 850 XP
2008 Can-am Renegade 800
2007 Arctic Cat 500
Old 03-01-2010, 06:10 AM
i dont know for sure the bolt pattern but im going to take an educated guess and say its a 4/156 pattern
well, as far as OEM hubs on the 2010 850 XP, the front hubs are OEM# 5135499 and are $37.48 each. machines that share this front hub are:
2010 SPORTSMAN TOURING EPS 550
2010 SPORTSMAN X2 550
2010 SPORTSMAN XP 550
2009 SPORTSMAN XP 550
2009 SPORTSMAN XP 850
2010 SPORTSMAN XP 850
2009 SPORTSMAN XP EPS 550
2009 SPORTSMAN XP EPS 850
2010 SPORTSMAN XP EPS 850
The rear 2010 850 XP hub is OEM # 5136946 and is $61.79 and the machines that match are:
2010 SPORTSMAN EPS 550
2010 SPORTSMAN TOURING EPS 850
Old 03-01-2010, 09:59 AM
4getful2's Avatar
Member #1234
you should be able to find some trailer hubs w/ 4-4 pattern then get wheel spacers-adapters to adapt out to your bolt pattern. 'bout the only solution out there.
Is there going to be enough space on your trailer for the tall ,fat tires?
Old 03-01-2010, 09:25 PM
LS1's Avatar
LS1 LS1 is offline
Member #3400
Thanks for the info, I will look up the drawing and see if this is an option. It may not be the greatest of plans, only due to ordering spindles, bearings, and seals. I will check the pricing.
2007 Arctic Cat 500
Old 03-01-2010, 09:34 PM
LS1's Avatar
LS1 LS1 is offline
Member #3400
I haven't thought of that, it does seem to be the best option. So, i guess the issue will be to find a company that will have adapters to make it work. It seems that this will be more of a one of a kind request? Due to Polaris' bolt pattern?
As far as fitment, I have plans on how to build to make sure there will be room. I have tossed up the idea of suspension, but I think it would hurt more than help due to varible weights of load. So if I were to go with out suspension, and adjust tire pressure, I should be good. It shoud look pretty good using a polaris wheel and tire combo, unlike the manufactured trailers offered.
2007 Arctic Cat 500
Old 03-04-2010, 05:54 PM
Grunthunter's Avatar
Member #2758
You can find hubs listed for sale on ebay. Just do a search on Polaris Sportsman parts and accessories and start digging through the 7,000 listings that pop up.
Old 03-04-2010, 06:11 PM
n2mudn's Avatar
Member #2174
the largest selection and quality hubs" for trailers" is a company called redneck. no joke! heres the link Redneck Trailer Supplies. there pretty cheap. i bought a new hub with lug studs and bearings for around $20.00-$30.00 for my boat trailer. worth a look!
2004 sportsman 600; 26" itp mxr wheels; itp ss212 rims; 3000 lb winch; rear dble tube bumper; 3" rack ext. frnt & rear; frnt brush guard; koplin hand guards; rear mad dog soft pack; 60" warn plow and a HEAVY THUMB!!
Old 03-04-2010, 09:47 PM
LS1's Avatar
LS1 LS1 is offline
Member #3400
I plan on running down to Redneck on Saturday, we have one here... Great place! That sounds damn good.
I think I am going to just make my own adapter for the bolt pattern with some aluminum I have, and have the holes machined. Then just pick up the polaris studs. Or, I may just give it a go on my drill press and be as exact as possible.
2007 Arctic Cat 500
4/156 trailer hubs
atv cart plans
atv kart plans
atv pull behind carts
atv pull behind trailer
atv pull behind trailer plans
atv pull behind trailers
atv pull behind trailers plans
atv pull trailers
atv pull trailers for sale
atv wagon for sale
atv wagon plans
pull behind atv trailer
pull behind atv trailers
pull behind trailer for atv
pull behind trailers for atv
trailer hub 4/156
trailer to pull behind atv
trailers to pull behind a polaris ranger
trailers to pull behind atv
ATV Trailer Opinions / Manufacturers BRKCOP ATV General Discussion 21 03-06-2010 01:14 PM
97 Xpress 300 - Oil in pull start Nandy Polaris Sportsman 2 02-27-2010 04:52 PM
99 400 pull starts help!!! slapstick Polaris Scrambler 3 02-15-2010 08:28 AM
Pull start doesn't work mnnightowl ATV Repair and Maintenance 2 01-07-2010 03:03 AM
Pull starting Sportsman 2ringer6 Polaris Sportsman 7 08-18-2009 05:34 PM
