Ethanol Bad ?? - Polaris ATV Forum
post #1 of 23 (permalink) Old 10-23-2012, 06:12 AM Thread Starter
Snipers215's Avatar
Ethanol Bad ??
Has anyone heard that the ethanol in gas is really bad for the ATV engines and we should add stabilizer with every tank full ??
A friend told me this yesterday, so i wanted to see if you guys knew anything about it.
Thanks, and i love this site.
YOUR GREATEST ADVERSARY... HIDES IN YOUR MIRROR.
Snipers215 is offline
post #2 of 23 (permalink) Old 10-23-2012, 08:45 AM
MTCPP's Avatar
My dealer told me to stay away from ethanol. Where I buy my gas the premium 91 octane has no ethanol. I have always used premium in my atvs and motorcycles.
Chuck
2012 550 X2 Green
Red Lodge, Montana
MTCPP is offline
post #3 of 23 (permalink) Old 10-23-2012, 09:07 AM
lost cause's Avatar
Ethanol is bad for all vehicles. New vehicles are better suited for it, but if you let it sit, it will put moisture in your fuel system. I put stabil in all my small engines and 5 gallon cans. Better safe than sorry.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N AIR FILTER
POLARIS 3500 WINCH
POLARIS OEM BELT
STOCK EXHAUST
lost cause is offline
post #4 of 23 (permalink) Old 10-23-2012, 09:12 AM
lost cause's Avatar
Also, there is no reason to run high octane fuels unless you have a custom machine with higher compression. It is nice if you can find ethanol free fuel, but I still add stabil with all my fill ups. Ethanol or not.
EPI HD SPRINGS
1.5" SPACERS
GORILLA AXLES
SUPER ATV ARMATURE
K&N AIR FILTER
POLARIS 3500 WINCH
POLARIS OEM BELT
STOCK EXHAUST
post #5 of 23 (permalink) Old 10-23-2012, 09:42 AM
Mystro's Avatar
Like Frankenstein would say Fire bad..... Ethanol bad. This should be a sticky because it keeps coming up. You need to Stabil marine ethanol treatment. (fluid is blue in color) You can find it at Walmart. A $20.00 bottle will last you a long time.
2010 Polaris 550 X2
aka..RRV "ricer recovery vehicle"
Polaris/Vision Rims w/ Vision trailfinder tires
Polaris extreme front / rear bumpers
Polaris winch, Heated grips/ throttle
GPS, LED aux lighting,
Ricochet A-arm Armour
Mystro is offline
post #6 of 23 (permalink) Old 10-23-2012, 12:39 PM
Scott6by's Avatar
aside from a slight drop in range/millage the problem with Ethanol in the gas is that it will go bad in the gas tank if you leave it sit for a long period of time.
if you use the machine enough the fuel won't go bad because you're always putting new fuel in. I use Sea Foam when I won't use mine for more then a couple weeks at a time though. still starts and runs like new! even on cold days.
Scott6by is offline
post #7 of 23 (permalink) Old 10-23-2012, 12:45 PM
cruzer's Avatar
gas stations have what 10% ethanol? if we dont add anything to it, what is it going to do?
2008 polaris sportsman 500 HO
27" ITP Mud Lights
ITP Wheels
SuperATV rear bumper
cruzer is offline
post #8 of 23 (permalink) Old 10-23-2012, 01:42 PM
MustBeNice's Avatar
I always put sea-foam in my gas can's and small engine equipment that ends up sitting for a week or more between uses and takes a while to use up a complete tank of gas.
My daily driver is a different story, as it generally does not sit for more than a couple days and a tank is used in a week or two. But I will run a can of sea-foam through it around every oil change @ 3-4,000 miles)
I use sea-foam as I'm not a fan of sta-bil. Every time I put in in my cycle for the winter, the carb needed a cleaning come spring ( I know you should anyway, but it ran like poo). Since I started using sea-foam it fired up and ran like I parked it yeasterday.
I've also heard many guys say "Quicklsilver" gas traetment is top notch product and swear by it.....
Matthew "MustBeNice"
Mods: Polaris 2500HD Winch - Synthetic Rope - MotoAlliance Line Stopper - Glacier3 60" Plow - Polaris Rack Extenders - Polaris Bumpers - LowPro Shield - Polaris Hand Guards - Warning Debadge - 3Way Head Light (Relay) - Cabelas Mirrors - Wes Ind. Std Seat/Box - Kolpin Fuel Pack Jr - 26" ITP MudLite Tires - HighLifter HD Springs - MotoAlliance Sirius 6" Pro LED Light Bar
MustBeNice is offline
post #9 of 23 (permalink) Old 10-23-2012, 03:46 PM
SMP63's Avatar
Ethanol is basicaly alcohol & will absorb moisture out of the air & cause the gas to start to go bad in as little as a week. It will help turn the gas to varnish quicker gumming up carberators & such. It also causes premature ageing & falure to fuel hoses. I also use SEA FOAM to treat my gas!
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
SMP63 is offline
post #10 of 23 (permalink) Old 10-23-2012, 04:50 PM
skizmo's Avatar
My bike sits for a month at a time from spring to fall and then sits all winter with maybe a few rips up and down the road, SEAFOAM is simply an amazing product. I never have an issue starting my bike and never bogs out. I will use SEAFOAM always in my bike for the remainder of its life.
Sea Foam | How to Use Sea Foam Motor Treatment
2011 550XP CAMO
skizmo is offline
Ethanol jaskjb ATV General Discussion 26 09-09-2012 11:41 AM
Ethanol fuel - oldrt ATV Repair and Maintenance 4 09-07-2011 10:22 PM
