Sea Foam - Polaris ATV Forum
post #1 of 26 (permalink) Old 12-14-2012, 07:06 PM Thread Starter
bobx2's Avatar
Sea Foam
My 850 has started to run poorly recently. Will not idle when cold and runs rough until it warms up good. I pulled the plugs and they were gas soaked. Seems to run okay after it is warmed up and has been run a while, but extremely rich when cold. I added Sea Foam in my last 2 tanks of gas just because I had never put anything in it before. That is when I started having this issue. Has anyone had this happen to them after using Sea Foam? Not sure why it would cause this, but that is the only thing I have done differently since I have owned it. The air filter is clean and the plugs are only a few months old. No codes are being thrown, so it would appear to be a mechanical issue. I'm going riding tomorrow so I will fill it up with no sea foam and hope it clears up. Any thoughts?
bobx2 is offline
post #2 of 26 (permalink) Old 12-14-2012, 07:30 PM
vortecz71wv's Avatar
Never had any issues with it, keep us updated though!!!
Matt
Mine:
2011 Sportsman 800
Polaris Front Brush Guard, Polaris Rear Brush Guard, Polaris Rear Rack Extender, Polaris L&R Rear Cargo Box, Warn 2500lb winch, Winch Saver, Ricochet A-Arm Guards (www.TheATVSuperStore.com), 3-High Headlight Mod, 6000k HID kit, Rigid Ind. 2xDually w/ strobe box, UNI Air Filter, 26" GBC Dirt Commanders, 1" Billet Wheel Spacers (Front and Rear) HighLifter HD springs, Dalton Primary Spring O\BL, Realtree Seat custom cover, Polaris Handguards
Wife's
2011 Sportsman 550XP
Polaris Front Brush Guard, Polaris Rear Brush Guards, Polaris Rear Rack Extender, 26" GBC Grim Reapers, Viper Elite 3000lbs Winch w/ wireless, Polaris Handguards, 6000k HID Kit
Fuel It, Flog It, Feel It!
vortecz71wv is offline
post #3 of 26 (permalink) Old 12-14-2012, 11:21 PM
Corbett1973's Avatar
I've found Star Tron to work better than Sea Foam for me.I can now use mid grade gas instead of ethanol free premium. Just a thought. Hope you get the bugs worked out.
07 500 EFI HO X2 Deluxe
25" Original Bighorns
Polaris HD Front springs front & rear bumpers
money is the root of all evil & man needs roots:
Corbett1973 is offline
post #4 of 26 (permalink) Old 12-15-2012, 10:46 AM
skizmo's Avatar
Bob I know you got a heck of a lot more experience then my self so its hard for a rookey like me to help trouble shoot something that you have not all ready done. But my 550 started doing what your describing and it was the throttle cable needing adjustment. - the wet plugs.
I have run sea foam in every tank of gas I have used and not encountered any issues (yet). I have used every gas from 87 at esso (10% ethanol) right up to 94 (ethanol free) at petro Canada and really never noticed a difference between any of them other then in my wallet.
2011 550XP CAMO
skizmo is offline
post #5 of 26 (permalink) Old 12-15-2012, 10:58 AM
gtsum2's Avatar
I use star tron in every tank of gas, but have used sea foam on other machines when they were not running right...sea foam always seemed to fix them up. I would guess it is something like Skizmo said above...odd for sure
gtsum2 is online now
post #6 of 26 (permalink) Old 12-15-2012, 01:35 PM
NoJoke's Avatar
I can't see of any reasoning to point at Sea Foam on this. Coincidence?.... Also, did you put in new plugs for your ride today?
NoJoke is offline
post #7 of 26 (permalink) Old 12-15-2012, 01:55 PM
Thomasj's Avatar
They run extremely rich during warmup. (Seafoam will richen it even more) We are constantly fouling plugs at the shop from moving them around here and there. Try to keep start ups to a minimum unless you actually going to warm up and ride the machine. Most fuel injected machines are like this but Polaris seems to be the worst about it.
How much seafoam did you use?
Thomasj is offline
post #8 of 26 (permalink) Old 12-15-2012, 04:28 PM Thread Starter
bobx2's Avatar
Not pointing any fingers at seafoam here. Just asking the question. After todays ride, I really don't think that is the cause. Once warmed up it idles fine and runs good, until you put a load on it. Then it really bogs down and will barely spin a tire or climb a hill. It can't keep the rpm's up. I have to put it in low to climb any kind of a hill at all. If it dies before it's warmed up, you almost can't get it to start again. It cranks over and starts to flood out. I understand the whole thing about minimizing start ups, but it won't even idle without applying the throttle when cold. As soon as you let off it will die and not restart. I know how it should idle during warmup, and how it used to, but it won't now. I did clean the plugs and they looked like new before I put them back in. I'm sure they don't look like new now after riding today.
Wondering now if maybe it isn't the TBAP sensor, or something along those lines. I think that could cause it to act like this.
bobx2 is offline
post #9 of 26 (permalink) Old 12-15-2012, 04:59 PM
Have you tried using MAF sensor cleaner on the TBAP sensor?
Just a thought...
Matt
Mine:
2011 Sportsman 800
Wife's
post #10 of 26 (permalink) Old 12-15-2012, 06:47 PM
fishhooker's Avatar
Sounds like your fuel pump pressure may be too high. Check your oil too, if you haven't yet, and see if you have fuel in it. My '04 had that problem (same symptoms and over fueling) when I got it, I put a new pressure regulator on it and no problems since. Or as you suggested the TBAP could be the problem too.
fishhooker is offline
Anyone use Sea Foam ? gregv92c ATV Repair and Maintenance 37 08-20-2016 08:40 AM
Sea foam 11bgrunt ATV General Discussion 4 08-20-2016 08:06 AM
Sea Foam? Kalani938 ATV General Discussion 11 08-23-2012 06:23 PM
Sea Foam used, now stalling when hot bgirard420 ATV Repair and Maintenance 4 04-03-2011 07:07 PM
replacement foam tbern Polaris Sportsman 5 02-17-2011 09:41 AM
