06 sportsman 500 HO wiring problem - Polaris ATV Forum
post #1 of 15 (permalink) Old 06-12-2013, 01:28 PM Thread Starter
polarisboy2013's Avatar
last night when i was hooking up my battery with my ratchet, i touched both battery terminals together . there was a spark. I went to try and start my bike and there was no juice to anywhere, except my winch. No lights or odo readings came up, no power at the lights either. my wich does work with the key turned on but not off as it should. i also just reinstalled my stator. im not sure if any of these wires would not give me power either. some help is greatly appreciated. almost tempted to bring it to a dealer
polarisboy2013 is offline
post #2 of 15 (permalink) Old 06-12-2013, 02:30 PM
500sportsman's Avatar
You probably popped a fuse.
05 SPORTSMAN 500 HO
Polaris hand guards
Polaris front and rear bars
Polaris rear rack extender
Rear LED reverse light
Front 16 inch LED light bar
3 headlight mod
500sportsman is offline
post #3 of 15 (permalink) Old 06-12-2013, 02:37 PM Thread Starter
hi there, thanks for the info, i was looking for where they could be and i didnt find any, just these boxes with (4) 3 prong metal connectors. is there a fuse box? and where is it located. thanks
post #4 of 15 (permalink) Old 06-12-2013, 04:21 PM
I'm not sure where the fuse box is but I'm sure they would have one, have you looked around the battery as well as under the front near the radiator.
05 SPORTSMAN 500 HO
Polaris hand guards
3 headlight mod
post #5 of 15 (permalink) Old 06-12-2013, 06:27 PM Thread Starter
Thanks for the help again. I did check. Took both plastics off. No fuses to be found anywhere, did some research and there is no fuses on the 06's polaris didn't think it through. May be the starter soilenoid wire going to the key, or Is it possible to short out the ECM.,
post #6 of 15 (permalink) Old 06-12-2013, 06:36 PM
InRBigness's Avatar
Unhook your battery (carefully this time LOL) and let it sit. The ECM may need to be reset. There are also circuit breakers in little pouches. Check them. Follow the power to the ECM and see if it is getting there. If not its a circuit breaker.
08 Sportsman 500HO
01 500HO Plow Machine
InRBigness is offline
post #7 of 15 (permalink) Old 06-12-2013, 06:52 PM Thread Starter
Okay I will try that, and don't worry will be carefull this time lol and what do these circut breakers look like? I was looking through my wiring and seen no pouches.also something I did just notice tonight, my winch will work for roughly 10 seconds after I turn my key to the on pos. Then it will just go dead. I can shut the key off and it will do the same every time. I will attach a photo if I can. I have 3 of these black rectangular boxes, one by the soilenoid, and 2 up front
post #8 of 15 (permalink) Old 06-12-2013, 07:09 PM
InRBigness's Avatar
You may also have killed a cell in the battery by shorting it out. Not likely but possible. Can you disconnect the battery and use cable to hook to a car battery and see what happens? The winch should run indefinitely and you may be surprised.
08 Sportsman 500HO
post #9 of 15 (permalink) Old 06-13-2013, 04:01 AM Thread Starter
Okay when I get home I will try jumper cables and another battery I know it good. And yeah that's what I mean, this bike has given me nothing but problems since I got the thing. The battery wasn't charging before so I took the recoil housing off and found the stator was full of rust and 2 of the 3 yellow wires coming from it were frayed off. In highschool and waiting for extra money, so had the bike 3 months and rode it twice. Now this. The gamble you make buying used
post #10 of 15 (permalink) Old 06-13-2013, 01:07 PM Thread Starter
well, its not the battery. took the old one out, gave it a while for the ECM to cool and tried a new battery. still nothing and the same with the winch, turn the key and it works for 10 seconds. im thinking it is most likely the ECM or maybe i shorted the key switch. any recomendations?
1999 polaris sportsman wiring problem JLH Polaris Sportsman 5 10-29-2012 01:16 PM
Help on an O6 Sportsman 700 (carb) wiring problem please mike3137 Polaris Sportsman 2 04-12-2012 09:43 PM
2004 Polaris sportsman 400 wiring problem Daleas88 ATV General Discussion 6 01-17-2012 04:36 PM
sportsman 600 wiring problem astrozombie ATV Repair and Maintenance 0 07-30-2010 07:49 AM
wiring problem with 04 sportsman 600 astrozombie ATV New Members 2 07-30-2010 05:04 AM
