'13 550 EPS Zerk Fitting locations? - Page 2 - Polaris ATV Forum
  #11 (permalink)
Old 07-30-2013, 07:32 PM
Treacherous's Avatar
Member #542
Thanks for info! I've been out of Polaris forums for a while. I used to be on ATV frontier years ago. I will be back with this new quad.
'13 Polaris 550 XP EPS (1K- miles/90 hours) (4/11/2013 build/Polaristar until 9/2018)(Road legal)
-Polaris Deluxe Front (2876595) & Rear (2876597) Brushguards
-Thor's best ATV mirrors
-Polaris Steel Front & Rear Rack Extenders
-Ricochet full 8 piece kit (black anodized)
-Cecco frame brace
-Silent Rider (ATV Silencer)
-WARN ProVantage 3500
-KFI Winch mount
-Polaris OEM grip & thumb heaters
-Polaris Front lock & ride box
-Thor's 3 Way ATV Hitch 1 1/4" Box type
'04.5 Polaris 700 SP EFI (3268 miles/302 hours) - Gen VI chassis (Original Owner)(Road legal)
'85 Honda TRX 250
Washington Off Highway Vehicle Alliance (WOHVA)
  #12 (permalink)
Old 07-31-2013, 07:57 AM
Member #542
Originally Posted by bartjude View Post
I was able to rotate mine and lube it from hole in footrest from underneath, utilizing a 90 degree tip on grease gun. My manual says three shots maximum.
Does it say that for all fittings or just the prop one?
-Cecco frame brace
-KFI Winch mount
'85 Honda TRX 250
  #13 (permalink)
Old 07-31-2013, 09:08 AM
faawrenchbndr's Avatar
Member #34872
2012 550 EPS LE, Blue Fire
Cecco frame braces
JCCapri bushing kit
Maxxis BigHorns
Ricochet skid plates (full kit)
Polaris rear rack extender
Polaris front brush guard
Warn ProVantage 2.5k winch
AmSteel Blue synthetic winch rope
Custom billet hawse fairlead
Denali 60" mid mount plow
  #14 (permalink)
Old 07-31-2013, 02:24 PM
bartjude's Avatar
Member #26732
Just prop shaft.
  #15 (permalink)
Old 07-31-2013, 07:29 PM
Member #34872
Service manual states until all traces of water have been expelled
Cecco frame braces
JCCapri bushing kit
Maxxis BigHorns
  #16 (permalink)
Old 07-31-2013, 07:56 PM
skizmo's Avatar
Member #13773
I was all ways told to grease until it starts to expel the old cruddy grease,wipe clean and Bam! done..
2011 550XP CAMO
  #17 (permalink)
Old 07-31-2013, 08:42 PM
Member #542
Thanks all!!!
-Cecco frame brace
-KFI Winch mount
'85 Honda TRX 250
  #18 (permalink)
Old 08-01-2013, 04:16 PM
Member #542
Which 90 degree tip are you using?
Do you think this one will be fine?
I went through and greased everything today. Not sure all zerks were really well lubed so decided to play it safe. All but one in right rear near diff could I get a decent fit on with flexible head grease gun.
Or maybe this one:
-Cecco frame brace
-KFI Winch mount
'85 Honda TRX 250
  #19 (permalink)
Old 08-02-2013, 09:09 AM
Member #542
I was able to finally get that last one that was giving me problems in rear. I can definitely see where 90 degree will have value in doing this easier. I used the following grease gun.
-Cecco frame brace
-KFI Winch mount
'85 Honda TRX 250
  #20 (permalink)
Old 08-02-2013, 07:05 PM
TIP's Avatar
TIP TIP is offline
Member #20201
Tretcherous, I have the same grease gun as you but I put another length of flexible pipe on the end. This way I can lay under the front and grease it easily with my fingers coming in from both sides to get the gun on the zerk. The longer hose allows the gun to lay on the floor until I am ready to pump it. I then can hold the tip on the zerk and with other hand reach down and pump the gun. I just found it easier. I have a hoist in my garage so I just lift the one end at a time and set it on stands so I can lay right under it. Floor jack would do the same thing.
2013 grizzly greese fittings location
2013 polaris 550eps zerk fitting locations
2013 yamaha grizzly 550 greese fittings locations
grease gun fittings
grease gun swivel fitting
is there grease fittings on a 2013 grizzly 550
steering zerks on grizzly 550?
where are the grease fitting on my polaris 550 x-2
where are the zirk fittings on 2014 polaris 550 eps
yamaha grizzly 2013 greese fittings
yamaha grizzly 550 grease zerks
zerk lock on fitting
Zerk fitting where? 2Tanks Around The Garage 1 04-10-2013 03:50 AM
grease zerk fitting question jordaman17 ATV Repair and Maintenance 5 03-27-2012 12:13 PM
how to replace a zerk grease fitting mpittman ATV Repair and Maintenance 2 01-18-2011 02:23 PM
Sportsman grease fitting locations?? ptlmbutler ATV Repair and Maintenance 6 11-21-2010 03:34 AM
zerk fitting size jgroesbeck ATV Repair and Maintenance 2 07-06-2010 07:30 AM
