Old 08-22-2010, 09:19 AM
chevmn56's Avatar
Member #6620
Question Clunking Sound
Hello all i am new to this sight so i hope this is not a well known topic.....anyway i have just purchased 2 2008 800 EFI Sportsmans V Twin i just got back off a 65 mile ride and noticed a bad banging sound when going down hill on rough rock roads sounds like metal on metal but i am not sure. I can fill this banging on my feet. I am not sure about the other machine i fit does it to, but man it does not sound right, or good.
Has anyone else come across this before any input would be appreciated
Worried owner
Old 08-22-2010, 09:27 AM
Canaan's Avatar
Member #6589
Check your front struts?
Old 08-22-2010, 09:28 AM
Canaan's Avatar
Member #6589
OOPs? and welcome to the board
Old 08-22-2010, 10:16 AM
Old 08-22-2010, 12:37 PM
chevmn56's Avatar
Member #6620
Thanks for the welcomes everyone. What exactly am i looking for on the struts?? bushings???? i know the struts are not bottoming out.
Thx
Old 08-22-2010, 01:42 PM
Canaan's Avatar
Member #6589
Check for range of travel for the strut,,,see if it hangs up,,,,bushings.
I had a strut leak its fluid and clunk like that,,,start from there
Old 08-23-2010, 04:08 AM
Member #1958
You might want to check the roll pins that hold your drive line yokes onto the transmission and differential shafts. I had one back out and was whacking the transmission housing. If you feel it in the right foot well it may be the yoke on the front propeller shaft next to your foot.
Old 08-23-2010, 02:09 PM
chevmn56's Avatar
Member #6620
I do fill it in my right foot ill check that tonite
Thanks to all
09 sportsman 800 efi clunking by my right foot
2010 polaris 500 with a clunking sound
2010 polaris sportsman 500 clunking noise
atv banging noise transmission
clunking in polaris 800 atv when starting move
clunking noise in the front shocks of a polaris sportsman
clunking sound from the front of my polaris sportsman
my polaris sportsman clunks when i turn
polaris 500 foot well
polaris atv 800 sportsman twin 2008 stall when turn right
polaris atv stalls turning right
polaris atv with sounds and light
polaris atv with sounds and lights
polaris sportsman "clunking" sound
polaris sportsman 500 clanking sound
polaris sportsman 500 front shock clunking?
polaris sportsmans rear suspention make clunk
sportsman 500 strut clunking
yoke noise
Clunking sound????? chopperdude ATV Repair and Maintenance 3 07-02-2010 08:10 PM
09 xp 850,clunking xpman Polaris XP 40 03-11-2010 02:58 PM
08 500 HO Gearbox? Clunking when stuck dub190 Polaris Sportsman 5 10-26-2009 04:56 PM
Clunking Noise ItODDospeed ATV Repair and Maintenance 4 10-06-2009 03:49 AM
New Problem - Clunking in front axle on 450 asylum Polaris Sportsman 4 06-20-2009 05:38 PM
