08-31-2010, 01:12 PM
Member #5005
Which snow plow do you have and reccomend?
I am leaning toward the Warn provantage 60in with power pivot (possibly)
We do snow removal in driveways and parking lots. I have heard that there are issues with the plow tripping way to easy. I do not want this. Do you have any opinions? Also polaris came out with a Glacier 3 for 2011. I dont know what the difference is though. Also i would let the plow ride on the skid shoes rather than direvtly on the wear bar. Is this what yall do?
2010 Polaris 850XP LE crimson red edition.-TOTALED
Pure polaris front and rear deluxe brush guards.
Pure polaris front and rear a arm guards.
Pure polaris lock & ride tall windshield
Pure polaris lock & ride gun scabbard
Pure polaris steel rear rack extender
ITP terra cross tires
Maxxis RAZR 4 speeds
UNI air filter
oury grips
RATH racing pre runner style chromoly bumper (front)
Ricochet Skid Plate (chassis)
Hot seat performance hypershift clutch kit
SSI decal kit
Powermadd handguard factory rider.
For any of your performance needs I would go with only Hotseat performance. I dont work for them just love there GREAT service and their amazing products[/SIZE][/SIZE][/SIZE]!
08-31-2010, 01:38 PM
Member #2920
I have a Moose plow on my 850XP. It works very well and has some nice adjustable shoes to set your plow depth on the surface that you are plowing. After some trial and error I got the blade tension just right so it doesn't trip over unless I hit something that is too strong for my quad to push (i.e. curbs, manhole covers, ect.
I have been pleased with it performance. It just doesn't come with the quick disconnect feature like the Glacier or Warn systems. It uses a mounting plate that is on the bottom of the quad.
 - Polaris 3500 Winch
- Viking Hause Fairlead and Safety Thimble
- Elka Stage 1 Triple Rate Shocks with Rebound
- Front Lock n Ride Storage Box
- WES Lock and Ride Rear Touring Box
- Rotopax Front Storage Fuel Cells
- Hand Warmers
- Garmin GPSMap 62S
- 27" Grim Reapers
- 8000K HID Lights
08-31-2010, 04:10 PM
Member #3625
I purchased a Warn 60" plow about 2 months ago and am still waiting on all of the parts. When I got the blade there was nothing in the box except the blade and wear bar. No bolts, return springs or even directions and I'm having a hell of a time getting the pieces that I paid for. Another problem with the Warn plow is the front mount. It seems like a good way to use a plow but if you want to leave the plow mount on the four wheeler all the time you have to leave the front plastic fairing off of the bike because it cant bolt on with the mounting bracket on there (looks like shit). My situation my be rare but if I was going to do it all over again I would NOT get the Warn plow.
08-31-2010, 04:22 PM
Member #5005
Which Plastic fairing are you refering too? I have had great luck with worn and the reason I dont want to go to a polaris plow is because I have heard the quality is not as great as the warn. I will most likely have my dealer install the plow no matter which I get. About how many hours did it take you to put it on? does the mount cut down on ground clearence? My dealer charges 65 an hour labor soo.. haha
UNI air filter
oury grips
SSI decal kit
09-01-2010, 11:43 AM
Member #3625
It's the plastic around the winch. The bracket for the blade uses the bottom bolt holes that the plastic uses and you cant have both bolted in at the same time. The quality of everything seems good and I finally got my parts today.
09-01-2010, 03:34 PM
Member #5005
Is that the XT 30? And Couldnt you just get longer bolts so you can have both attached at the same time?
UNI air filter
oury grips
SSI decal kit
09-16-2010, 01:05 PM
Member #7310
I use a 60 inch SnowSport ATV snow plow on my Polaris, I have used it for three years now. It do wonders, easy to install, and take off, I highly recommend it. I bought it from a company called BuySnowSportPlows:
ATV Snow Plow Blade | Snow Plow for ATV or UTV
Let it snow, let it snow, let it snow!
09-16-2010, 02:58 PM
Member #3625
Yes it's an XT30. I will have my plow completely installed this weekend and do a complete write up on it. You can't use longer bolts because the mount is in the way of the plastic fairing.
This is not a very good pic but this is what the bracket looks like installed.
09-16-2010, 04:33 PM
Member #7044
Polaris Glacier II plow.
I have an `07 800 efi and I decided on the Polaris glacier II 60" plow and mount. The plow & mount came to $530 including tax. Has the adjustable saddles and the easy on/off is nice. The only extras I may be interested in are that flap for the top and those little whip like things for the left & right of the plow.
My buddy that has one suggested to get a heavy rubber flap to put on the bottom of the plow to help save the wear bar, actually you wouldn't be using the wear bar as the rubber rides on the surface. He said it's cheaper to replace the rubber than the wear bar.
Take care,
Scott Deeter
09-16-2010, 08:10 PM
Member #4866
just got done installing my g2 60" plow only took about a hour to put the whole thing together, on, and semi adjusted(waiting on winter)
cost me $475 after taxes
ill be posting a thread tomorrow or sat all about it
fyi if u have a front brush guard it comes really close to hitting but doesnt dont know how close a warn or any other type will come
2010 850 XP EPS Stealth Black
from dealer
2500lb. winch (with wireless remote)____60" Glacier® II Plow System with extras___Lock & Ride® Front Cargo Box____Rear Rack Extender___Moose hand and throttle warmers
HID Plug and Play Light Kit for 550/850(www.theatvsuperstore.com) lower lights tinted with 20% window tint (still brighter than stock but not blinding bright)
Front & Rear A-Arm Guards XP550/850 2010(www.theatvsuperstore.com)
28" zillas on stock 14" rims(http://www.4wheelparts.com)_____26" stock tires on itp ss212 14" thanks SNW629
Deluxe Front/Rear Brushguard(http://www.superatv.com/)
3 in 1 Polaris atv hitch from (www.theatvsuperstore.com) might i add it was a gift they sent me just for buying some stuff
Galls® 100W Remote Siren (http://www.galls.com/)
lots of lights
motor cycle radio
(still to come Wes Standard(rear seat and storage), dalton clutch kit, 2 inch lift, stealth snorkel kit if they ever make them for the 2010 )
2010 polaris atv snow plow aftermarket, 4 wheeler snow plow, glacier 3 plow price, glacier snow plow 60, how to install snow plow shoes, installing polaris plow on 4 wheeler, installing snow plow on atv, moose front mount snowplow for atv, polaris 3 snow plow, polaris 850 plowing snow, polaris 850 snow plow, pure polaris snow plows, rear mounted snow plows, snow plow for 850 polaris, snow plow kit for polaris 4 wheeler, snow plows for polaris atv no whinh, snowplow for 850 polaris 4 wheeler, snowsport plow forum, warn power pivot problems#gsc.tab, warn vs glacier snow plow
