I recently aquired a 2000 Scrambler 500 4x4 (4 stroke) and im not sure the best way to drain/flush/refill the cooling system. I would appreciate any advice I can get.
Thanks for the welcome. I actually figured it out pretty easily. The radiator has a petcock on the right side bottom corner. Drain/flush/refill and done. Very simple. I flushed out the green prestone and refilled with Engine Ice coolant. Flushed out the reservoir also,all quite easily.
113.2K members
