Newbie 700 ranger TPS - Polaris ATV Forum
post #1 of 3 (permalink) Old 09-19-2016, 04:04 PM Thread Starter
Troy78's Avatar
Hello all just signed up. And yep you guessed it. Looking for some help. I have a 08 700 ranger and having the old TPS issue. Problem is I followed the long version. Set my TPS to .528 with butterfly closed cable disconnected and idle screw backed off. Adjusted idle screw so TPS was reading .660v. Readjusted pedal cable so I had full sweep to 3.6v and now it disent even run. Any thoughts ? Note. Kinda strange I had to turn the idle screw down 2 1/2 turns to get from .528 to .660. Unit is over fuelling and backfires. ?
Troy78 is offline
post #2 of 3 (permalink) Old 09-23-2016, 03:27 PM Thread Starter
Troy78's Avatar
Update on my machine. Turns out I had a bad plug wire. Hence when I set the TPS it would stumble and stutter. One plug white an one black. After getting new plugs and wires I set my TPS to .580 base an .710 idle. Funny though I rechecked my vin and it is a 08. When I used the 08 spec I .528 and .660 my idle was to low. Idle should be 1150. Top end RPM is around 5500 in high gear.
Troy78 is offline
post #3 of 3 (permalink) Old 09-23-2016, 04:04 PM
bp405's Avatar
Welcome to the forum. Just an FYI this is the atv forum there is a ranger specific forum: RangerForums.net - Polaris Ranger Forum. You'll probably get more responses over there.
2011 sportsman 800 efi
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
bp405 is offline
Help 08 700 ranger Troy78 ATV Repair and Maintenance 0 09-19-2016 08:11 AM
Sportsman 700 Crankshaft Brawndo ATV Parts Wanted 2 06-07-2016 05:18 PM
Bluebook on 2006 700 ranger crew Plainshunter ATV Purchasing and Price 3 06-06-2016 03:29 AM
700 Crankshaft for sportsman or ranger m2cyclone ATV Parts Wanted 2 04-21-2016 05:22 AM
Polaris Ranger 700 nFLOW nFLOW Motorsports 1 03-04-2016 03:54 AM
