2000 Polaris Xplorer - Polaris ATV Forum
Old 02-15-2011, 04:24 PM
ajmicek's Avatar
Member #11636
This is my first machine and two weeks into having it, i had it apart in my garage putting on a new piston and rings. it runs now and has good compression (about 120psi), however 10min into running it, it seems down on power. i need help! its a 2000 polaris xplorer 250 two-stroke.
All help would be greatly Apperciated!
Thanks!
Old 02-15-2011, 06:47 PM
old fart in MO's Avatar
Member #6145
Did you rebuild the carb?
Old 02-15-2011, 07:09 PM
randygpolaris's Avatar
Member #11417
when i rebuilt my 2000 400 i ran double oil the first tank. just added a couple onces per gallon in the tank. is your oiler working? is the compression still good? did it get hot, is it full of antifreeze?
Old 02-15-2011, 10:08 PM
Old 02-16-2011, 09:27 AM
ajmicek's Avatar
Member #11636
@Randygpolaris It is air cooled, so it doesnt have antifreeze. And the oil pump works. no i haven't rebuilt the carb, it sems to be working fine. and im running Stihl 2 stroke premium oil (the kind i use in my trimmers and backpack blowers).
Old 02-16-2011, 05:32 PM
elmerkit's Avatar
Member #3805
I feel your eagerness on rebuilding your ride welcome aboard.
Old 02-16-2011, 06:11 PM
polarscott's Avatar
Member #3622
welcome to the board!
2010 Sportsman 500 HO
Old 02-18-2011, 04:22 PM
ajmicek's Avatar
Member #11636
thanks for making me feel welcome! so the day after i finally got it running, i went to start it up again and the pull cord was stuck. it felt like the piston was somewhat hydro-locked. so i took out the spark plug. nothing. so i took off the head. no movement still. i took the jug out and was back down to the piston and the crankshaft still wouldnt turn. so i took off the clutch gaurd and turned the clutch and fianlly it broke free of what it was held up on. so after i put it back together it ran good. now, however, the same thing happened. the pull cord wont budge. could this be the result of bad crankshaft bearings?
Old 04-01-2011, 09:25 AM
Whit8ker's Avatar
Member #13559
what was the reason for changing the piston?
Old 04-02-2011, 07:18 PM
Member #11417
sounds like the rod bearing and or the crank bearings could be a possibility. my rod bearing went out and it locked up, sounded like it ran out of gas. when yours quit, after you removed the jug would the rod & piston move freely on the crank ? if so, i would take a closer look at the crank bearings. you definately have a major problem some where. good luck and keep us posted.
2000 polaris 250 2 stroke carb
2000 polaris 250 xplorer compression
2000 polaris explorer 2 stroke piston o ring
2000 polaris explorer oil pump
2000 polaris explorer pistion
2000 polaris xplorer 250 compression
2000 polaris xplorer 250 stock compression
2000 polaris xplorer 400 4x4 flooding problems
compression for a 1999 polaris xplorer 250
polaris xplorer
polaris xplorer compression
2000 Polaris Xplorer 400 4x4 Engine Parts For Sale cyrjordan ATV Parts for Sale 3 03-11-2011 11:20 PM
2000 xplorer 400 question laan123 ATV General Discussion 4 08-01-2010 05:25 PM
2000 Xplorer dripping fuel nathan fjc ATV Repair and Maintenance 3 01-14-2010 07:31 PM
2000 Polaris Xplorer 425 issue sptrix ATV General Discussion 7 12-20-2009 09:13 PM
2000 Xplorer 400 3x4?? reese600 ATV Repair and Maintenance 0 03-17-2009 05:09 PM
