Old 12-10-2009, 07:16 AM
Alex's Avatar
Member #2259
1997 polaris 425 magnum front hub locking
changing hub oil usually fixs this but not this time,took apart to inspect but found everything looking ok.anybody got anwsers???
Old 12-10-2009, 07:25 AM
is it locked in or wont lock in?
Old 12-10-2009, 07:47 AM
Alex's Avatar
Member #2259
It locks in when it wants to andpulls to the right hard
Old 12-10-2009, 09:06 AM
is there a lot of slop on your yokes on the front drive shaft?
Old 12-10-2009, 09:26 AM
ahh, i think i might know.
from my time as a parts guy, i remember that when my mechanic was working on the front end of these machines and taking it part, he would ALWAYS ALWAYS ALWAYS have me order part #15. it is what activates and doesnt activate your 4x4. its glued against the strut assembly and when you start tearing into the front end you will almost always destory that part, especially if you are not aware about it. we would see atv, mostly older magnums that pulled hard to one side or the other, and those magnets seemed to be the reason why. still could be other things, but this is a strong possibility.
Old 12-16-2009, 04:55 PM
atvjunkie821's Avatar
Member #2326
My Magnum hubs will sometime lock in and stay locked even after pushing off. I have to back up for them to unlock. Changing fluid helps mine as well. I don't have the problem like yours where in locks in just riding though. The problem might be in the Hillard clutch itself, my brother had to take the rollers out of his and do a little polishing to get his working right on his 400l 4x4.
98 Trail Boss 250
94 400L 4x4
2007 Hawkeye 300
YouTube Channel:www.youtube.com/user/tinkerman01
Old 12-16-2009, 09:42 PM
Alex's Avatar
Member #2259
Question locking hubs
May have found problem,I was working on this unit for someone else and he had a zip tie around the reverse over ride switch and sometimes it would not keep the switch pushed in all the time,what that has to do with it,I don't know,but it has not messed up yet without zip tie on it.
Has anybody seen this done before???
Old 12-16-2009, 09:46 PM
Alex's Avatar
Member #2259
OH, by the way,both armature plates for the 4x4 coils,"magnets"were replaced and it still did it!!!!!
Old 12-17-2009, 03:17 PM
Member #2326
If you have any more problems you can disconnect the black wire from the speed limiter to disable it. It will not limit it reverse though. I done this to mine because I hate that thing, they go bad sometimes and cause crazy problems.
98 Trail Boss 250
94 400L 4x4
2007 Hawkeye 300
1997 polaris magnum
atv polaris magnum
how to check front oil hubs on a polaris magnum
magnun 425 hilliard clutch
polaris 425 1997
polaris 425 magnum diagram
polaris 425 magnum hilliard
polaris 425 magnum hub diagram
polaris 425 magnum hubs
polaris 425 magnum wiring diagram
polaris 97 front diagram
polaris front end diagrams
polaris front hub diagram
polaris magnum 425 front hub
polaris magnum front axle picture
polaris magnum hub diagram
polaris magnumfront hub oil
polaris support strut
