Originally Posted by cozycamp
I have a 1998 Big Boss 500 6x6 that sometimes won't start like it is on compression stroke & the starter (new) won't turn it over. Has new battery. The cam was changed last summer. Seems like it started after that. Any help would be appreciated. Thanks
Sounds like you have a flooded combustion cylinder. Remove spark-plug(s) and then crank. If fuel (or coolant if engine is water cooled) ejects from the spark-plug hole during cranking you either have a leaky carb (or a bad head and/or head gasket if engine is water cooled).
If fuel ejects, suspect faulty float valve and a blocked vent outlet at the bottom of the carb that allows float-bowl overflow to drain to ground via a rubber tube.
Clues to look for: High fuel consumption, smell of gas, sometimes wants to die at idle but recovers when throttle is thumbed open, and in extreme cases a gas puddle in the air-box.
Tips: Temporarily route the carb drain hose where the end can be monitored then look for dripping gas. If gas is dripping then schedule a carb rebuild.
