Old 01-01-2012, 03:37 PM
Dsholar's Avatar
Member #21855
400 sportsman not fully engaging in reverse
Hey everyone, I am new to this forum and I am hoping you can help me.
I currently own 3 Polaris atvs but I am having trouble with my 2001 sportsman 400.
I drives great in high and low Forward gears but when I shift into reverse I get a grinding or popping noise like it is not fully going into gear. If I ease in reverse really gentle it is fine but any pressure and the popping starts.
Atv has been taken really good care of and I service them accordingly. In addition too I road the atv every day for the last week with no issues in forward high and the 4x4 seems to work fine as well.
Any ideas?
Darin
Old 01-01-2012, 07:47 PM
Old 01-02-2012, 04:43 AM
pjmartin's Avatar
Member #5074
Send a message via ICQ to pjmartin
High and reverse are on the same linkage. I would try disconnecting the shift linkage and putting it in reverse by turning the bellcrank with a pair of pliers. If it engages properly without the linkage attached then it's probably a linkage problem. If it doesn't it's a gear problem in the gearcase. If the linkage is adjusted with a bias towards the High direction(too lòng, I think) then high would engage with some travel remaining in the shifter but reverse would be missing a bit of travel to fully engage.
I would try adjusting the linkage first. Check the oil in the shifter and make sure the shifter is securely mounted to the frame.
2001 Sportsman 500HO
Rear drop rack
2000lb winch
No mods
Old 01-02-2012, 06:16 AM
sportsman550's Avatar
Member #20828
Welcome to the forum!
Quad: 2009 Polaris Sportsman 550XP in beautiful sunset red with two way razor plow, tall windshield, 3500lb. Polaris winch, rear rest box and rear foot rests.
Previous ATV was a 2006 Honda 400 Canadian Trail Edition
Truck: 2003 GMC Sierra 1500 Z71 off road in pewter color, loaded with leather, heated seats, BOSE sound system and Onstar.
Previous trucks were: 1991 Chevrolet silver 1500 2wd reg long box and a 1998 GMC sierra 1500 ext cab 4X4 SLE
Tags
reverse issues
polaris sportsman 400 grinding noise
sportsman 400 making noise in reverse
polaris not engaging into high or reverse eddie55 ATV Repair and Maintenance 1 10-28-2010 05:52 AM
2000 Sportsman 500 4x4 not engaging colbyhonda50 ATV Repair and Maintenance 3 04-25-2010 11:27 PM
reverse over ride not engaging rkelley13 ATV Repair and Maintenance 2 01-25-2010 08:52 AM
03 sportsman - 4 x 4 not engaging jester7406 ATV Repair and Maintenance 4 01-04-2010 05:15 PM
'04 6X6 not charging fully kev_alaska ATV Repair and Maintenance 0 06-01-2009 10:07 AM
