Old 01-09-2012, 06:01 AM
gepp's Avatar
Member #22119
2001 sportsman 6x6
ive got 2 problems i need some advice on first ive got gas coming out of what i thing is an overflow? hose on the back of the carb and lets it run onto the tranny? case. also my starter seems to be jamming. it happened once before and i was able to free it by pulling the starter cord. appreciate any help anyone can give me. gepp
Old 01-09-2012, 06:45 AM
tt425's Avatar
Member #3687
Float needle is stuck in the carb or the needle seat assembly is bad. Remove carb,disassemble,clean and inspect needle for wear. The starter drive is worn out or you have rust on the flywheel gear thats causing it to hang. Clean flywheel teeth with a wire brush or sandpaper. If spring is broken or teeth worn on starter drive replace it. dbelectrical has aftermarket starter drives or maybe some of the site sponsors may offer an aftermarket starter drive.
Old 01-09-2012, 07:09 AM
gepp's Avatar
Member #22119
2001 polaris 6x6
thanks for the instant reply. gepp
Old 01-09-2012, 11:50 AM
2001 polaris 500 6x6
2001 polaris 6x6 sportsman 500 transmission
2001 polaris sportsman 500 6x6
2001 polaris sportsman 500 6x6 recalls
2001 polaris sportsman 500 6x6 transmission cover
2001 polaris sportsman 6x6
2001 polaris sportsman 6x6 picture
2001 polaris sportsman 6x6 starter switch
2001 sportsman 6x6
atv forum polaris 6x6
how to remove the transmission from a polaris 6x6
how to remove transmission from polaris 6x6 atv
polaris 6x6 2001 transmission
polaris 6x6 forum
polaris 6x6 starter location
remove starter polaris 2001 sportsman 6x6
sportsman 6x6
uninstall a transmission for a polaris 6x6
what carburetor does a 2001 sportsman 6x6 have
where is the starter switch on a polaris 6x6
2001 sportsman 500 HO remofire ATV General Discussion 4 04-11-2011 03:16 PM
2001 Sportsman H.O. Mrastatine Polaris Sportsman 2 03-22-2011 08:36 PM
2001 sportsman 500 HO only 3wd john bouy Polaris Sportsman 3 12-28-2010 01:28 PM
2001 Sportsman 400 dewars912 ATV New Members 6 06-17-2010 06:36 PM
2001 sportsman 500 HO hangonbigd Polaris Sportsman 1 05-21-2009 06:55 PM
