Old 01-10-2012, 06:36 PM
no1deacon's Avatar
Member #22177
Angry 99 scrambler 500 ignition problem
When I start my 500 scrambler 4x4 it runs rough until it warms up. It runs pretty good until it really warms up. It then is hard to keep running and stalls out eventually. If I try to crank it over after it stalls it will start up if I don't touch the throttle, but runs really rough and stalls out. If I hold the throttle wide open while trying to turn it over it does nothing but backfire thru the muffler. If I let is cool down for about a 1/2 hour it will start back up and run pretty good until it gets up to operating temp again then the same thing happens. This problem has gotten continually worse over time. It now takes less time for this to happen. I felt it was something in the ignition and looked at replacement ignition parts on line and found 4 things in the magneto section that I feel could cause this problem. The only problem they total almost $1000. Where do I start?
Old 01-10-2012, 07:02 PM
And welcome to the board!
500 scrambler runs rough
99 scrambler 500
how do you start 500 scrambler
polaris scrambler 500 stalls when running wide open
polaris scrambler500 ignition parts
scrambler 500 running rough
Ignition problem?? summer lynn ATV Repair and Maintenance 1 11-15-2011 09:36 AM
03 TrailBoss 330 ignition problem mmcb ATV Repair and Maintenance 2 07-25-2011 05:16 PM
'11 Sportsman 500 Ignition Problem twk87 Polaris Sportsman 12 05-16-2011 04:41 PM
Preditor 90 ignition problem? jyarosz ATV Repair and Maintenance 1 12-03-2009 06:44 PM
Ignition problem Martin ATV Repair and Maintenance 13 09-24-2009 08:25 AM
