Old 01-13-2012, 11:20 AM
Denny's Avatar
Member #21509
02 sportman 700 4x4 issue Denny
Hi I am new to this so kinda bear with me pleez,I have a 2002 700 that the speedo took a dive on me , my son a while back emailed me a fix that he said he got off of this forum.The fix involved jumping certian wires so that the front diff. was wired to the high beam switch. I have no front engagement now ecept if I give it gas then it slams into 4 wheel so i leave the switch off.Easiest fix im sure is buy a new speedo but,$$$$$! Im not tight just broke!! Someone help
Old 01-13-2012, 02:16 PM
Old 01-22-2012, 06:47 PM
ibhogn2's Avatar
Member #7371
Denny, did you find any help? I am working on a 03 700 for a friend. Came to me with a bad rod bearing. Put in new bottom end, rings, valves. Test drove today a noticed that the speedo screen is blank, no speedometer, no odometer, obviously everything in the screen is gone, no 4x4 engagement. Main question, is the 4x4 thing because of the speedo head not functioning?
Old 01-23-2012, 05:47 AM
Denny's Avatar
Member #21509
engagement issue
No I havent heard a word on 4x4 nobody wanted to talk i guess, what i did was went thru archived posts and got a little help still not clear if you have to go thru speedo.
Old 01-23-2012, 10:42 AM
ibhogn2's Avatar
Member #7371
Tell you what Denny, talked to my friend today and he wants to put in a different speedo. I don't know if you are willing to wait that long but when I get it put in, I'll let you know if that was the issue. He figured even if it is something else causing the 4x4 to not engage, he has to have the screen functioning anyway. I'll keep you posted.
Sportman 500 michspea ATV New Members 1 10-25-2011 03:48 PM
99 Sportman 500 timing issue dlh ATV Repair and Maintenance 3 07-29-2011 05:22 PM
04 sportman 500 ho mikey51 ATV Repair and Maintenance 2 01-23-2011 06:30 PM
A site issue or IE browser issue? tech geeks look here! blueline15 Site Issues & Suggestions 15 03-31-2010 01:58 PM
97 sportman 400 4x4? keith24k Polaris Sportsman 2 05-27-2009 11:09 AM
