01-14-2012, 06:16 AM
Member #22284
2012 Polaris Sportsman squeaking
Hello guys and gals,My Polaris is squeaking real bad in front shock area.I don't recall hearing it the first day I drove it?The next day I drove it started squeaking real bad somewhere up front around shock area.Will this sqeaking stop after break in period?It was a cold 30 degrees outside when it started sqeaking.Any ideas on how to stop the sqeaking?It only has 17 miles on it.Any help will be appreciated.
01-14-2012, 06:36 AM
Member #19639
Mine did the same thing. It turned out to be the exhaust/muffler shield rubbing something. ????? I took mine back to the dealer and the adjusted the sheild not to rub.
2012 Polaris 850 XP Sportsman Touring
EPS
2500 lbs winch
Hand, Thumb and Rear hand warmers
Front Dry Box
Spill resistant beverage holder
27" Outlaw Tires
More Mods to come.
1999 Polaris TrailBoss 250 2 stoke
Well Used
01-14-2012, 06:38 AM
01-14-2012, 07:05 AM
Member #19639
To be sure... While it is squeaking, put your fut on the muffler with a little pressure and see if it quits sqeaking.
EPS
2500 lbs winch
Front Dry Box
27" Outlaw Tires
More Mods to come.
Well Used
01-14-2012, 10:07 AM
Member #11247
Its your front.suspension. Mine did it annoyingly bad for awhile. Grease it and keep riding. It will go away as it breaks in.
Sent from my SCH-I510 using Tapatalk
2011 Trail Boss - HIDs SOLD
01-14-2012, 12:42 PM
Member #22284
Thanks for info and welcoming me.
01-14-2012, 06:30 PM
Member #9679
Mind does it on the front suspension too. Seems to happen in the winter when the plastic is cold.
01-14-2012, 07:36 PM
Member #20681
My 500 squeaks at the top handlebar pivot. Of course, this part is non-greasable... Has 65 miles on it...
2012 Sportsman 500, Red.
01-15-2012, 05:21 AM
Member #22284
Thanks again for information.
2012 polaris 400 ho break in period, 2012 polaris ranger squeak, 2012 polaris ranger squeaks, 2012 polaris sportsman 400 ho review, 2012 polaris sportsman forum, 2012 polaris sportsman forums, 2012 polaris sportsman recalls, 2012 polaris sportsman squeak, 2012 sportsman 500 squeak, is there a way to stop my 2012 polaris ranger from squeking, new atv squeeking, new polaris 400 squeaking downhill, polaris 400 ho squeking noise, polaris atv squeaking, polaris ranger front tires squeal, polaris ranger suspension squeaking, polaris sportsman squeak in reverse, polaris sportsman sqweakes at low speed, squeaky suspention on my 2012polaris sportsman 500 ho, why do the brakes on my polaris sportsman 500 squeak
