Old 01-17-2012, 03:20 PM
WaitingGame's Avatar
Member #22284
Slow leak in both front tires
I have a 2012 Polaris Sportsman 500 H.O.with 17 miles on it.At first the right front tire had a slow leak and now both front tires have a slow leak.What brand of tire sealant do you guys and gals recommend or is there a better fix.My rims are steel.Any help will be appreciated.
Old 01-17-2012, 03:26 PM
starpuss's Avatar
Member #16228
my 2011 Also Started off like yours. But now All 4 of them Have a Slow leak!
want to know how i am going to Fix it!
Buy a NEW set of Rims And Tires! the Stock ones Suck!
2005 polaris predator 500cc
1997 polaris xplorer 400
1977 yamaha it175cc
1994 Suzuki RM250
1982 Yamaha YZ250
Old 01-17-2012, 03:28 PM
Old 01-17-2012, 03:52 PM
tekrsq's Avatar
Member #6432
The front tires have leaked on my 08 since I bought it.
08 Sportsman 800 Touring- 2500lb Polaris winch, front & rear brush guards, front rack extender, headlight Mod, Quadovator temp gauge, RAC Engineering reverse/ work lights, Polaris rear storage box
05 Scrambler 500 (wife's bike)- Polaris rear rack, Bear Claw tires
Old 01-17-2012, 05:35 PM
SeanE1987's Avatar
Member #16252
The right front tire on my 2011 x2 leaks around the bead, one fo my friends has a 2011 500 ho that does the same thing, guess its kinda common
1998 Xplorer 300-Stock
Old 01-17-2012, 05:57 PM
starpuss's Avatar
Member #16228
one thing my local dealer told me to do , , , is Pump it up to like 25 PSI!! and let it stay like that over night then lower it
i never did it... But should help set the tires on the rims
1977 yamaha it175cc
1994 Suzuki RM250
1982 Yamaha YZ250
Old 01-17-2012, 06:01 PM
whiskeyrider's Avatar
Member #12109
I use Berrryman's, it is white. You can find it at parts stores. It works well for me,WR.
Old 01-17-2012, 06:02 PM
shui5612's Avatar
Member #19703
3 things you guys should try doing...
1. take the tire off, make sure there isnt any sand/pebble that it between the rim and the tire... this is maybe the most probable one....
2. check for leaks, aka "bathe" the tire in a soapy water... maybe there is a small puncture...
3. might be corrosion, or you have a bad valve in the tire (improbable),
another thing that might be wrong is the pressure... a TOO low pressure may cause your tire to "get off" the rim in some mere instances while riding, like a tight turn on a trail...
fixes:
1.clean rim and tire
2.patch up the punctured area...
3. first id recommend upping the air...
i now ride about 10psi front and 10 psi rear on my x2, some times 7 but i usually pump it up to 10 before winter... no problems what so ever...after i have done this..
my 850's tires dont leak but they are both @ 7psi.
now, if this doesnt fix it, you can always try to add some "slime" in there... it works... but so so... but it WILL patch up a small puncture that you might have skipped... (remember i said CLEAN the rim and tire and as the last step add the slime... dont want to add it only to have to remove it afterwards...(and yes the brand i use is called "SLIME")
if all those fail, id try replacing the tire valves... although its very improbable...
but for the cheapest fix, and fastest, pump more air into the tire...
each 6 degrees Celsius is about a 1 PSI drop in a tire...
AND, theres a process called "effusion" which is air going out through tiny pores in the tire, now the stockers being "cheap" as some would say, it might be the thin sidewall itself that causes the air to go out more freely,
in that case, you can either, use slime, get new tires, OR if you can get this done for cheap, have your tires filled with Nitrogen (N2) as the molecule itself is bigger it either takes more time for it to escape OR it just wont be able to escape through most of the pores.
2007 800EFI X2 Deluxe
-polaris 2500# winch
-tool grips
-VIP air windshield
-safety flag (polaris)
-Glacier II plow system
-front hitch
-1700KM
2010 850 XP EPS
- 2500# polaris winch
- VIP air windshield
-498KM
Old 01-18-2012, 04:43 PM
Member #22284
Thanks for information.Before I got on forum tonight i put 15 psi in all tires.If they still leak i will try 25 psi.If this does not work they get slimed!!!
Old 01-18-2012, 04:48 PM
Slime will get the job done.
2012 polaris sportsman 500 stock tires
atv slow tire leak
atv ties with slow leak
both front tires leak
how do you know you have a slow leak in your tire
is there a rear brush guard polaris xplorer 400
polaris xplorer tire psi
what to do with a slow leaking tire
Front Box Leak Sportsman 500 industroman Polaris Sportsman 6 11-19-2011 05:14 AM
slow tire leak around rim ncmtns ATV Repair and Maintenance 8 02-05-2011 06:40 AM
Front Diff leak.. Easy fix? JP8 ATV Repair and Maintenance 3 11-21-2010 11:39 AM
Front Housing Leak daughtrylc ATV Repair and Maintenance 2 11-11-2010 04:49 PM
ADC leak on front diff. 2007 800 efi awags Polaris Sportsman 2 12-28-2009 01:55 PM
