Old 01-22-2012, 09:48 PM
trhill's Avatar
Member #22578
New sportsman owner.Lights problem
I just bought a 2005 sportsman 700 carb and when I turn on high or low beams they turn on and off almost like a strobe. Have a lot to do to 700 so any help would be appreciated.Also who has good prices on tire?
Old 01-23-2012, 03:56 AM
bgirard420's Avatar
Member #11494
Sounds like the PO may have potentially done something to intentionally it to get it to strobe (as seen on youtube LOL) or it's a failed relay/diode. If you haven't already, I'd take the pod cover off and see what you find under there.
As for tires, the atvsuperstore and discount tires direct are sponsors here who sell tires and it's always nice to support those who support the forum. That being said, shopping around the net never hurt especially if you can find a discount code or coupon. I ended up at mudthrowers because they had the ones I wanted in stock and I had a discount code.
2010 Sportsman 500 H.O.
Old 01-23-2012, 06:00 AM
Old 01-24-2012, 08:50 PM
trhill's Avatar
Member #22578
Thanks for the tip. I will check it out and also thought that maybe a loose ground could be at fault.
Old 01-24-2012, 10:18 PM
antoniodef's Avatar
Member #11247
Is it a consistent flash, or random? If it is consistent, like a cop car, I would say the previous owner did something. If it is random, you have an electrical problem. Open up the pod light and see what is going on. Follow the wires from the bulbs back to the switch and see if there are any problems.
2011 Trail Boss - HIDs SOLD
Old 01-27-2012, 12:05 AM
trhill's Avatar
Member #22578
Thanks for help, I will check it out. The lights don't start blinking at first but after about a minute they do. Not a fast strobe just like on then off. Same thing on high and low beams.
polaris atv light problems
help with electrical problem (lights) CJF Polaris Sportsman 4 11-02-2011 07:56 AM
Police lights and strobe lights jules Polaris Sportsman 16 04-04-2011 09:00 AM
Noob owner with major problem Puddin ATV Repair and Maintenance 3 06-15-2010 09:39 AM
Hey everybody. Newbie owner with major problem. Puddin ATV New Members 4 06-10-2010 04:14 AM
Problem with Extra Lights on Rangers tearitup184 ATV New Members 2 10-26-2009 06:11 PM
